Help me Preserve this Airbag!!!
Old Jan 23, 2003 | 05:38 PM
92GTA's Avatar
I just bought off of eBay what is basically an NOS airbag for my GTA. As you can see from these pictures, it has absolutely NO warpage of any kind!
This is bar-none, the BEST condition 90-92 Airbag I have ever seen!
Now the big question, how the hell do I keep it this way? Is there some kind of special glue I can put on the back edge of the cover where it wraps over the mold to keep it from warping and coming off like other airbags?
Old Jan 23, 2003 | 08:19 PM
BORLAZ06's Avatar
http://www.spacebag.com/
Old Jan 23, 2003 | 08:23 PM
92GTA's Avatar
I'm confused
I do plan on having the airbag in my car. I'm even going to send the airbag with my steering wheel when it gets recovered to they can perfectly match the height and color of the leather on the wheel to the airbag so it looks factory perfect again. I just need a way to prevent the airbag from warping like all other factory airbags...
Old Jan 23, 2003 | 08:35 PM
BORLAZ06's Avatar
ooohhh...didnt know u were goin to put that air bag in ur car. thought u were goin to preserve it. hahaa.
i cant really answer ur question.
Old Jan 23, 2003 | 08:39 PM
92GTA's Avatar
Yup, no sense in having a mint Airbag in storage while your mint car needs one
Old Jan 24, 2003 | 11:46 AM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
That's a tough one.
Old Jan 24, 2003 | 12:39 PM
Guest
Guest
Posts: n/a
GFL.
The sun does it. If you can keep the heat off the cover, it shouldnt ever do that. Good luck, gets hot in Bakersfield.
Maybe cover it in a liquid nitrogen wrap whenever you leave the car
Old Jan 24, 2003 | 12:51 PM
92GTA's Avatar
I figured it was the heat but the airbag in my Firehawk isn't even this nice and it's kind of a sure thing that it hasn't really been parked in the sun allot
So bascially I can do nothing but keep a cover on the steering wheel if I park in the sun and put a shade in my windshield and crack my windows to let the heat escape in the summer?
That sucks
Old Jan 25, 2003 | 12:55 AM
Guest
Guest
Posts: n/a
From what I have seen, yea. Seems like they used the same 'glue' on everything in the car. I have a console, and an armrest, both of which are really old, and in really good shape. They've never really seen the light of day either. Every thirdgen I've owned has had a problem with the outer part separating from the inner. I found out living in Fresno that newer Firebird consoles dont like heat at all.
I guess you could try covering it with cloth, see if that does any good. I'm still convinced heat is more of a factor though.
Old Jan 25, 2003 | 01:03 AM
92GTA's Avatar
Well if I can't really prevent it then I won't go out of my way to do things for it.
There's not another type of glue that may help the problem?
Old Jan 25, 2003 | 01:12 PM
Drew's Avatar
The thirdgen airbags never fit the steering wheels for ****. The horn buttons on the airbag you posted are already starting to warp. There is no way i've found to repair a warped airbag, and there's no easy replacement.
The airbag in my convertible is still nearly mint, but it still doesn't match the steering wheel.
They all warp. The way I look at it, it doesn't matter. Its a 90-92 Firebird, its going to have a warped airbag.
Maybe try an aftermarket cover?
Old Jan 25, 2003 | 01:15 PM
Drew's Avatar
BTW, its not the glue that's to blame for firebird consoles falling apart... Its simply that the vinyl that GM wrapped around the plastic frame shrinks over time. That's why the airbags warp, the consoles fall apart, armrests bulge up, dashes crack, etc... Heat/cold just accellerates it.
Old Jan 26, 2003 | 02:22 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I am glad I do not have an airbag. I don't have to worry about it. If I want a different steering wheel I just install one.
Old Jan 26, 2003 | 02:31 PM
92GTA's Avatar
I can just install any wheel I want too. I just happen to actually like the look of the 90-92 Firebird steering wheels...
Old Jan 26, 2003 | 02:49 PM
92TRANSAMWS6's Avatar
Yup, Just like anything else, the airbag can be removed.....I still have my airbag and it's in perfect shape if ya ever need another one.
InfernalVortex
Apr 20, 2021 11:31 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Eric-86sc
Feb 25, 2016 09:02 PM
tealman92
Sep 28, 2015 01:43 PM
tattmann
Sep 27, 2015 05:20 PM
