what gears did i have stock
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
i would like to know what gears my car had stock, ie heard 3.73's and someone else said 3.23's which ones are in my car? its a 89 camaro rs wih a 2.8 v6 and a 700 r4 trans
Transmission: autos
what is the differance, like does it have better accleration with 3.23's? what gears where in a 85 2.8 v6 with a 700 r4? the 85 was my old car and this one seems alot quicker in low end, but slower in top end than the 85 was, that thing would haul going 60 and nail it...lol get up to 80 pretty quick...not like a v8 bt still..
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
Originally posted by 1991tealRSt-topGuy
2.8 autos came with either 3.42's or 3.23's
definetly not 3.73's
S/E's were always sort of the rulebreaker, for one thing. my 84 2.8V6 HO 700R4 is a 3.73 as part of the WS6 package. RPO GT4. car is the beige/gold one shown below on the right. I'm sure there are other thirdgens that could have the combo. Would you believe that even a four-cylinder car could have 3.73? Well it's true. Credit delete Iron Duke Firebird S/E with WS6 package is perfectly valid, AFAIK.
the only way to know FOR SURE what your car has is to get under there and check the axle codes, or better yet open it up and take a look. if you're not up for that, check your RPO codes. codes starting with the letter G will have something to do with the axle (usually). look 'em up on the RPO decoder of this website.
Car: 1989 RS Camaro
you've got 3.42 gears. I've got a 89 RS Camaro with a 2.8L V-6 with a T-5 and its got 3.42 gears. In 89 both auto and manual 2.8 RS's came with 3.42 gears and a limited slip.
Transmission: autos
yup sounds right, why is it both my tires only spin sometimes, like my concrete driveway one spins on asplalt 2 spin???
Transmission: autos
well if it wasnt limited slip, why would both tires spin sometimes my old car wasnt and only the right tire spun
Depends on what wheel gets traction. Again check your RPO codes for G80. And why is so important that you burn rubber with a V-6?? Also the advantage of the Limited Slip (aka Posi) is to gain traction not lose it.
Transmission: autos
not that its important, i just thought it was odd that sometimes both spin sometimes only one spins, ill go check the code in a few
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
