how much am i looking at possibly
Old May 15, 2003 | 08:15 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Well ive got an 2.8L 86 sport coupe now, soon to be repainted, by the end of the summer, im hoping to sell it, and with the money in the bank, and that i save from working i want to buy an IROC. Is it difficult to find an IROC with Ttops and a 350 motor and a manual tranny? thanks
-Greg
Old May 15, 2003 | 08:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
No such thing was ever built by the factory. You can find 350 & T-tops; 305, T-tops and manual trans; but no 350 and 5-speed, ever.
Find a good 305 5-speed T-top car with a tired motor and install a "bore kit".
Old May 15, 2003 | 08:36 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hmmmm
or you can just put a 350 in it istead of a (bore kit)
with dropping a 350 in it youd be way better off in the end the more cubes the better.
Old May 15, 2003 | 08:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
"bore kit" for a 305 = a 350 block
Old May 15, 2003 | 08:53 PM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
"bore kit" + 305 = im an idiot
Old May 15, 2003 | 09:59 PM
Engine: 400
well yeah i would go for a 305 manual tranny, i dont know i just want ttops though, and its gotta be an iroc-z
Old May 16, 2003 | 06:23 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I didn't think you could bore a 305 out to a 350. I know they are basically the same, but I thought that was out of reach.
I knew you could stroke them to 335.
On the other note T-Tops rule. I wouldn't have a thirdgen without them. Well except maybe for a TTA.
There is a science to putting them on. I always put mine on emphasizing the front seal. If you push them as far to the front as you can they are less likely to leak. Good luck.
Old May 16, 2003 | 06:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
a 350 block
You're right, you can't bore a 305 out to a 350; that's why you have to go to the junkyard and pick up a "kit"
Old May 17, 2003 | 08:39 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It would be possible to buy new sleves for the pistons, and make a 305 into a 350, unfortunately it is NOT cost effective, 350s are plentiful, get one from a truck, I might even consider a 96-98 350 Vortech, and then get thyself a TPI baseplate from Scroggen-Dicky...
John
Old May 18, 2003 | 03:18 PM
MdFormula350's Avatar
my first car was a decent 198 camaro iroc-z fully loaded 5.7 t-tops, i paided 3 grand for it and it needed about 200 more dolars in it to pass inspection.
just have to shop around. around my way i couldnt find a iroc-z 5 speed with t-tops and the 305 tpi, but would be a nice combo to have.
Old May 19, 2003 | 09:10 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Have fun finding one with a stick. they aren't "rare" but they are uncommon. Uncommon enough that just about every car guy I have shown my car to are suprised to see that it is a stick.
Old May 22, 2003 | 10:40 PM
pheonix305's Avatar
Car: 1986 Trans Am
Engine: built 305
Transmission: 700r-4 shift kit
if im not mistaken it is impossible to bore a 305 out to a 350. you would have to bore it .15 over and that is impossible you would have to stroke it to.
Old May 23, 2003 | 07:44 AM
okfoz's Avatar
You would have to re-sleve it... They do it for airplanes all the time...
John
Old May 23, 2003 | 01:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
350 bore = 4.000"
305 bore = 3.736"
a - b = .254" (how far you'd have to bore a 305 to make it a 350)
There's nowhere near that much metal
Re-sleeve = $40 or more a hole, $320 for a whole motor
Junk block = $50-100
You decide
Old May 28, 2003 | 08:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yea, just do like I did... pull a decent (well, mine was shot, but thats another story) 305 out of a 5 speed/T-top car and just put all the 305 parts on the 350 block. All of the parts will interchange with no problem unless the 305 is a roller block ('87+) then it may have a few issues.
Basically, just get a 350 without heads, intake, exhaust, etc etc and take all that stuff from your 305 and drop it on. All my 305 stuff is on a 350 block and its great.
One thing though... if its a TPI 305 you end up with, you will need bigger injectors for the extra 45ci.
LC2 TECH
Oct 13, 2015 11:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
mfp189
Sep 27, 2015 09:25 AM
