Have a look at this
Old Jun 13, 2003 | 09:56 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Have a look at this
I found this while searching for the build sheet. I found it behind the radio. Anybody got any idea of what it is?
It says : F CAR I.P TEST RESULTS:1 TIME 00/09 02:39
CHEVY U21 LB9 A31 A90 T56 ( or so i think it says, kinda hard to tell because the paper is not in perfect condition)
Old Jun 13, 2003 | 10:49 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Could this be something from the factory. That would be really cool. Anyway the hunt for the build sheets continues.
Old Jun 13, 2003 | 12:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Instrument Panel (I.P.) QC sticker
Old Jun 13, 2003 | 01:30 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Ohh what is that?
Old Jun 13, 2003 | 01:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Instrument Panel
You know, that flat thing behind the steering wheel with all those "instruments" in it
Old Jun 13, 2003 | 01:45 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Yeah i know i was just wondering about the sticker. Did they test the panel at the factory and then put the sticker there?
Old Jun 13, 2003 | 02:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Of course. They test everything they possibly can before they build it into a car.
Visit a car assembly plant sometime. It's a fascinating experience, well worth the trouble for anyone even dimly interested in working on cars. You will learn things you didn't even know you didn't know.
At the instrument panel factory, the entire dash assembly as it will go into a given model of car, is completely assembled, with its wiring. It has one giant plug behind the fusebox (which is included in the dash wiring harness, by the way) and a couple of other plugs that interface to other things that have to plug into the dash harness (A/C power supply wire, SES light, steering column & ign sw, body, etc.). They simply plug each of these connectors into a test fixture to verify that the dash performs as it's supposed to. Then it goes to the vehicle assembly plant, with its wiring attached, ready to bolt into a car and plug everything in.
That sticker is from where the dash assembly for a car with those RPO codes (one of a handful of dash part numbers that would have existed for these cars in that year) passed its final test.
Old Jun 13, 2003 | 02:36 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Those are RPO codes.
U21 LB9 A31 A90 T56
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
T56 : Unknown (T53-T99 relate to Lighting, it may have to do with dash lighting)
John
Old Jun 13, 2003 | 04:15 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Thank you. Its always nice to find old papers hidden in the car.
Old Jun 13, 2003 | 09:00 PM
David M's Avatar
Car: '84 Z28
Engine: L69
Oh yeah, I agree with that. I try to tour our Doraville assembly plant once a year, even though they make mini vans the car building process is just fascinating.
Doraville assembly 1986-2002
Norwood assembly 1987
Lakewood assembly 1990
Van Nuys assembly 1992
Bowling Green assembly 1994
Shreveport assembly 1998
Old Jun 14, 2003 | 07:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's right, it's the process that's so interesting; it would be nice to see one of the exact kind of car you're working on as it's being built, but just knowing the chunks that a car (almost any car) is broken up into, where the dividing lines between the various modules of it are, etc. is incredibly useful knowledge. I think of the trouble I've gone through taking something apart, a dash for example, without realizing that if instead of trying to take every wire off the back of the cluster I should take the entire wiring harness out with the cluster and it will take about a quarter as much time.... stuff like that.
Old Jun 14, 2003 | 03:22 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Thank you guys for the answers. I guess i have to visit the Volvo factory sometime.
Old Jun 15, 2003 | 10:19 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i've been to the lordstown assembly plant twice, where they build the cavaliers and sunfires.
i would have loved to have been able to have toured the norwood plant.
Old Jun 15, 2003 | 11:00 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
or the van nuys plant
Old Jun 16, 2003 | 05:59 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
T56 today refers to the 6 speed tranny, but I have no clue what it would be on a 3rd gen!!!
I just looked at it again and it's actually T96. Those are fog lights.
Old Jun 17, 2003 | 10:11 AM
okfoz's Avatar
Fog Lights: That would make sence considering they have to wire for the Switch.
John
Old Jun 18, 2003 | 02:56 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Of course it should be t96. Sorry but it was hard to see on that paper.
