ttop differences?
Old Jun 29, 2003 | 06:35 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
ttop differences?
I'm looking at a set of TTops as a backup set for my '87 IROC.
They look to be from an 85-92 car. Are there any fitment issues with a different year?
Also, does having keys REALLY help or is it kind of a gimic option?
Old Jun 29, 2003 | 07:47 PM
MdFormula350's Avatar
you can change your locks to your backup set if u need to.
the early years used hooks to hold the t-tops down. then came along the glass ones with small pins, and other glass ones had large pins, then other versions were made with lexan/acrylic and used large pics also. then you have the aftermarket t-tops that had c&c on them, which wont fit at all.
when i lost my passengers side large pin lexan t-top, i had an extra glass small pin passengers side i used for a few weeks.
all i had to do was simply lossen the moutning holes behind the plastic trim pieces and move them around alittle at a time to get the small pins to fit in right.
Old Jun 29, 2003 | 08:28 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Any idea if the 87's had large or small pin?
Old Jun 29, 2003 | 09:13 PM
https://www.thirdgen.org/techbb2/sho...ght=ttop+years
https://www.thirdgen.org/techbb2/sho...ight=ttop+pins
Old Jun 30, 2003 | 03:38 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Its the same for Camaros and Firebirds right, the latch style I mean. I thought only Firebirds came with the hooks.
Old Jun 30, 2003 | 02:02 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
All Pins all years (84-92) were the same, I have a set of "Large Pin" Acrylic tops and all the larger part of the pin is a sheeth, and it pushes into the top.
The Locks are nice to keep them from getting stolen...
John
69GTOby
Apr 18, 2016 02:34 PM
MORREALE5
Sep 13, 2015 09:01 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
scottmoyer
Sep 7, 2015 07:06 PM
