what color is the bottom of 3rd gens?
Old Nov 23, 2003 | 10:20 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
well for me its the lovely color Rust, but in the process of restoring the car i want it to look all original. what color is the underside of these cars? its just a primer gray color right?
Thanks a bundle!
Old Nov 23, 2003 | 11:23 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Primer grey and rust on all unpainted parts after a few months.
Such as rear axle, exhaust, rear LCA's,sway bars and etc.
Old Nov 23, 2003 | 04:57 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Some of it is primer grey and some of it is body color overspray.
Old Nov 24, 2003 | 01:41 PM
GTADave's Avatar
Car: 1989 20th Anniversary Trans Am
Engine: 3.8 ltr Turbo
Transmission: 200r4
In addition to some of it being gray primer and body color, the suspension parts (axle, control arms, sway bars, springs are all a semi-gloss black.
- Dave
Old Nov 24, 2003 | 02:03 PM
Guest
Guest
Posts: n/a
The control arms up front are not all painted. The outer part of the arm where the ball joint is was not painted, the line runs approximately from where the turning stop is to the back. Almost all of them that I have seen have orange paint on the end like an inspection mark or something.
Old Nov 24, 2003 | 02:10 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Here is a good pic of the primer and the original red overspray.
Old Nov 24, 2003 | 03:08 PM
GTADave's Avatar
Transmission: 200r4
On my 19K mile GTA (which I have owned for 11 years), it never had the orange paint marks you refer to. I am not saying all 3rd gens are not pained with these marks. It can be different from year to year and between the two plants.
- Dave
Old Nov 24, 2003 | 03:14 PM
DJP87Z28's Avatar
Remenber most under body parts on 3rd Gen cars were not painted. The only rear axle being painted black was the BW 9-bolt. Thats why there is so much rust on the underbody.
Old Nov 24, 2003 | 03:37 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
colors may have changed throughout the years but check the underside of this guy's 2719mile '86 Z28 in this thread.https://www.thirdgen.org/techbb2/sho...highlight=1986
Old Nov 24, 2003 | 04:30 PM
Guest
Guest
Posts: n/a
Could be. Like I said, most of the control arms I have seen are like that.
Old Nov 25, 2003 | 03:18 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Dark Gray/Yellow Overspray...
John
Old Nov 26, 2003 | 05:37 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Rust/Dirt/Oil.
Old Nov 26, 2003 | 05:42 AM
88txiroc's Avatar
This might help a little. I know........it has been posted several times............
Old Nov 26, 2003 | 05:50 AM
GTA4ME's Avatar
Where the he!! did you get that pic?!?!??!
Old Nov 26, 2003 | 07:51 AM
okfoz's Avatar
The rumor is that its an 89 TTA that a dealer put on its side for a display, I believe it was back in 89. Notice that they put it on a mattriese to protect it a little.
When I have worked on my car I sweaer that the bottom is actually the charcoal color that my lower stripe was, the only reason I have a little yellow down there is from when I painted it in 1997. And the black is from my SFC's and all my parts I powdercoated
Please realize that my car is a Norwood car, and it is very possible because of their painting process that the entire underbody was put in the "Turbo Bell" with the rest of the car, so I would think that the car would have been yellow all over at one time, and then painted gray on the bottom, I could be very wrong here tho...
John
Old Nov 26, 2003 | 09:12 AM
GTA4ME's Avatar
I sure hope they took the side mirror off!
Old Nov 26, 2003 | 09:25 AM
okfoz's Avatar
thats what is holding up the car from rolling onto the top
John
Old Nov 26, 2003 | 09:27 AM
GTA4ME's Avatar
That sure doesn't do much for resale value!
Old Nov 26, 2003 | 07:32 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
John
it is indeed a tta. look at the transmission pan. it's a dead giveaway.
Old Nov 26, 2003 | 07:54 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Hey, I'd take that TTA... Even if it had frame damage form that stunt, I'd sure love to have a TTA with the stickers still in the box. ...sigh...
My car has a really fresh coating of corrosion prevention compound, in the form of MOTOR OIL from my bad filter seal... Stinking jiffy lube... Oh well, free undercoating.
Old Nov 28, 2003 | 07:20 PM
CDN_87IROC's Avatar
Here is my factory grey bottom with red overspray
Old Dec 1, 2003 | 12:13 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Is there something different or special about the 82 Z28's? I ask because my z28 appears to have galvanized sheetmetal underneath. Its really cool, there is absolutely no rust, discoloration. Just a nice shiny galvanized zinc color under the dirt.
69 Six Pack
Oct 5, 2015 07:51 PM
Warlocksirix
Sep 3, 2015 12:26 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
