need answer about a 87 camaro rs
Old Dec 16, 2003 | 08:17 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i am looking at buying an 87 camaro rs it was originally an american car but it has been a canadian car for 3 years were there any differences i should look for?
basically is it all the same thing just made in the states?
Old Dec 16, 2003 | 09:30 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
What sort of things are you thinking of.. As far as I know the only difference was some of the guages are different. I do not think there is really any difference to it.. Escpecially if it has been imported to Canada three years ago.. it would have gone through the instections.. I would make sure (if you have not done so) is Get a "Lein" check done on it. I think thats spelled right. Just to make sure there is no money owing on it anywhere.
Old Dec 16, 2003 | 09:35 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
yeah i was just wondering if it was mostly the same except the gauges and as far as a lein check goes all done thanks for the reply though
Old Dec 20, 2003 | 09:22 PM
cdartz's Avatar
If it's an 87 then it's an SC, not an RS, unless it came from California where they had a limited run of RS badged cars. For the rest of the U.S. the RS didn't make it's apprearance until 89.
Old Jan 3, 2004 | 03:21 PM
reverend007's Avatar
I've read that Canadian cars carried Daytime running lights as standard equipment.
Old Jan 3, 2004 | 04:49 PM
Car: 89 Camaro RS
Engine: 305 TBI
Mine doesn't have it...
Old Jan 4, 2004 | 01:33 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
As of 1990 all new cars brought into Canada required daytime Running lights.
Used cars: only cars of 1990 vintage or newer require daytime running lights when brought into Canada.
Local emissions requirements apply -- In BC's lower mainland/FraserValley we have AirCare... Cars newer than 25 years (i think) are required to be tested.
jklein337
Sep 19, 2018 06:23 PM
Caspar
Jun 19, 2016 11:19 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
formula_novice
Aug 18, 2015 08:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
