Where were the engines built?
Old Dec 28, 2003 | 12:29 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
I was just wondering where the motors for our cars were assembled. I know the cars were assembled in Norwood and VanNuys, but were subassemblies completed at other plants? So where were the motors cast and/or assembled for our cars? I would guess that the casting numbers on the motors would reveal this...but my motor is in my car at the moment I have an LG4, my car was assembled in Norwood.
Example, I know ford manufactured 351's in Clevelend and Windsor...so where did chevy make their motors. Did VanNuys or Norwood have different suppliers?
Thanks, not a major issue, but I was just curious Thanks for any info.
Old Dec 28, 2003 | 01:41 AM
82RECAROTA's Avatar
Old Dec 28, 2003 | 08:59 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I recall that some of the carb'd engines were built out of St.Catherines in Canada.
Mark.
Old Dec 29, 2003 | 07:30 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
My 87 LG4 was built in MEXICO, if I was told correctly, I could tell by the big ole "M" on the back of the block.
John
Old Dec 29, 2003 | 08:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My block was cast in Canada.
Old Dec 30, 2003 | 07:29 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
The engine date must precede the car build date, otherwise something is amiss. Some engine machining operations (decking) will obliterate the engine ID.
Engine ID Code Example: V0101CLJ - (V = Plant, 01 = Month, 01 = Day, CLJ = Engine Suffix Code)
Another example: T0830CTY - (T = Tonawanda, 08 = August, 30 = 30th day, CTY = 1970 396 Camaro, 375 hp, 11.0:1, TH400)
Code Engine Plant Code Engine Plant
F Flint (Motor) S Saginaw Service
H Hydramatic T Tonawanda
K St. Catherines, Ontario V Flint (Engine)
(McKinnon Industries Canada)
M GM of Mexico
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
NWAsonoma
Aug 18, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
