WTF? My car is so a Iroc-z
Old Jan 27, 2004 | 05:36 PM
Macey's Avatar
Car: Black 1988 Camaro Iroc-z
So i use the rpo decoder like everyone else and lone behold the results come back with me having some interesting things. My car is an iroc-z 305 TPI 5-speed vin 1G1FP21F8JL145980. Alot of stuff seems to be incorrect....hhmmmmmm. tell me what you think. is it normal for these things to be off?
Made in: United States
Manufacturer: General Motors
Make: Chevrolet
Carline Code: F-Body
Carline Series: Camaro (all models)
Body Type: 2 door coupe (hatchback)
Restraint System: Manual belts
Engine Code: 305 ci V8 LB9 (1987-1992)
8 is the CHECK DIGIT
Model Year: 1988
Assembly Plant: Van Nuys
Production Sequence: 145980
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A01 : WINDOW, TINTED, ALL SHADED, W/S
Unable to locate code A3D in our database!
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D35 : MIRROR, OUTSIDE REAR VIEW
Unable to locate code D60 in our database!
D81 : SPOILER, RR, AERO WING
B88 : MOLDING B/S CUSTOM
E5Z : SPEEDOMETER ADAPTER (DELETE)
Unable to locate code E7Z in our database!
Unable to locate code E92 in our database!
GU2 : AXLE REAR, 2.73 RATIO
J50 : BRAKE SYSTEM, POWER
K60 : GENERATOR, 100 AMP
L03 : ENGINE, GAS, 8 CYL 5.OL TBI
[B]MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4[B]
Unable to locate code MX0 in our database!
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
N90 : WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
PB4 : LOCK CONTROL, WHEEL
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
Unable to locate code UQI in our database!
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
WW2 : APPEARANCE PACKAGE(SILVER), AERO #2
W62 : ORNAMENTATION, AERO PACKAGE
Unable to locate code X05 in our database!
Unable to locate code X15 in our database!
Unable to locate code X18 in our database!
Unable to locate code Z31 in our database!
Z49 : EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
16P : WHEEL COLOR, BRT WHITE (91)
6XU : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7XU : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
Unable to locate code 721 in our database!
729 : SEAT BELT COLOR, DK CARMINE (9) (91)
8UX : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
81U : PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
86A : STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9UX : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Old Jan 27, 2004 | 06:05 PM
Steve86TA's Avatar
Car: To many to list
Does the vin# on the rpo sticker match the # on your car?Maybe the console was from a different car
Old Jan 27, 2004 | 06:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Macey,
I haven't been able to find all of the codes for you, but I did find a few. I was unable to find A3D, but I did find a AD3 which is window, hinged roof.
D60=Color Override Trim Paint Compatibility
E7Z=Sensor, Vehicle Speed Delete
E9Z=Speedometer Key Delete
UQ1=Radio Provisions For Stereo
72I=Interior Trim, Dark Carmine
The Trickster
Old Jan 27, 2004 | 06:20 PM
Macey's Avatar
Consol
Here are the results for your query on: 1g1fp22e3jl160958
Make: Chevrolet
Restraint System: Manual belts (built in safety)
Engine Code: 305 ci V8 L03 (1988-1992)
3 is the CHECK DIGIT
Model Year: 1988
Production Sequence: 160958
Car
1G1FP21F8JL145980
Make: Chevrolet
Model Year: 1988
Mystery solved Thnx
Old Jan 28, 2004 | 01:04 AM
iroc22's Avatar
Yeah it's not unusual for a console to be swapped out. I've run into the problem of the SPID sheet being different from the VIN on the car. Confuses the hell out of you until you realize the VIN's are different.
Old Jan 28, 2004 | 05:23 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
16P brite white wheel color. This sounds to me like an RS. Time for Willie to jump in!
Old Jan 28, 2004 | 05:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by Macey
Consol
Make: Chevrolet
Model Year: 1988
Car
1G1FP21F8JL145980
Make: Chevrolet
Model Year: 1988
Mystery solved Thnx
Read his last post Kevin, console VIN doesn't match car VIN.
The Trickster!!!!!!!!!!!!!
Old Jan 30, 2004 | 06:27 PM
Car: FBODYS
Engine: ALWAYS 8'S
WOW now I really think I need glasses. Sorry about that guys.
Old Jan 30, 2004 | 06:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No Prob, I had to read it twice also
Old Feb 7, 2004 | 03:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Wouldn't an '88 with RPO Z28 be an IROC?
Old Feb 7, 2004 | 05:30 PM
iroc22's Avatar
Yes
Old Feb 8, 2004 | 07:00 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Yes, that label was from a VERY basic Iroc-z. I mean bas-ic! (power nothing/L03/2.73's/auto/15" wheels) Wierd however, whoever ordered it specifically ordered it with white wheels. The trim paint override code is noted below, and the standard iroc wheels in '88 were gray or gold.
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
