Firebird seat availability
Old Feb 10, 2004 | 10:36 PM
MikeS's Avatar
This may be a basic question for those up on options, etc..
What years (and/or models) would my style seats have been available in? I don't know if they are Firebird specific, or limited to certain years, etc. Anybody know? I'm looking for a replacement driver's side bottom front seat cushion, but don't ever seem to find this shape.
Old Feb 11, 2004 | 12:26 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Look into other GM's for seats like those, especially Pontiacs (or maybe only Pontiacs) like the Sunbirds and Grand Ams. If you need just the bottom seat part, it wouldn't matter if the reclined or not as you could swap your reclining mechanism over.
I have similar seats in my 89 Formula, and my 86 parts 'bird had the deluxe version of them with the pouch on the back of the upright.
Old Feb 11, 2004 | 01:10 PM
Drew's Avatar
The lower seat cushion with the leg support seems to be Firebird specific. The Grand AM/Sunbird seats usually don't have the additional support.
Look to later Firebirds.
Old Feb 11, 2004 | 03:51 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
My 87 TA has those exact seats with the pouch in the back of the upright.
Old Feb 11, 2004 | 09:49 PM
MikeS's Avatar
Mine also have the pockets on the backs of the front seats. I was asking because they don't appear to match any of the advertised replacement covers (thirdgenresource and Hawk's). They look different to me. Bruce at Hawk's said he could get the covers for me no problem though. I just need to replace that bottom cushion you can see in the top of the pic. I'll try calling around and see if I can't locate some 'birds 87-92 in the yards before I head out to dig around. Thanks for the input.
Old Feb 11, 2004 | 11:05 PM
Guest
Guest
Posts: n/a
You'll need to find an 86 or 87 to get that exact style.
Old Feb 12, 2004 | 10:09 AM
MNformula350's Avatar
I had seats like those out of a 84 Trans Am
Old Feb 12, 2004 | 11:28 AM
Guest
Guest
Posts: n/a
The seat base is slightly different on the 84 and 85. I think the back is different too.
Old Feb 12, 2004 | 02:30 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
My 92 T/A has the same "rocker/recliner", no pocket in the back tho.
Old Feb 12, 2004 | 07:05 PM
MikeS's Avatar
madmax,
Thanks for the years, that's what I was looking for. Just to clarify...
Does that range open up any if I disregard the pocket on the back? Since I will be recovering, I don't think that I'll be able to keep the pockets.
MikeS
Old Feb 12, 2004 | 07:51 PM
91zconvt's Avatar
Car: 87 Iroc
my '89 Grand Am LE winter beater that I paid $5 for has those seats. Don't know if they're stock, but they're power and they're in there.
Old Feb 13, 2004 | 01:08 AM
Guest
Guest
Posts: n/a
Depends on what exactly you're looking for. The earlier and later seats have a slightly different design/curvature of the seat foam and possibly the frame. All will bolt up fine though, of course. If you dont care about what they look like, just use the same year parts on both sides.
Old Feb 13, 2004 | 09:48 AM
MikeS's Avatar
Ok, understood now. I really only need to replace 1/2 of my drivers side front seat, so doing that will have me looking at 86 and 87. If that doesn't work out, I'll have to look for a front set and can broaden my search.
Thanks.
Old Feb 13, 2004 | 11:35 AM
Guest
Guest
Posts: n/a
I bought a new seat because my upper seatback was cracked. I think I still have the lower, if youre interested. I'll take a look later today and see if its still floating around.
Old Feb 16, 2004 | 06:40 PM
MikeS's Avatar
That would definately be a solution to my problems. Let me know if you've still got it around and would part with it.
Old Feb 17, 2004 | 10:12 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Apparently the foam was bonded to a frame and is sold as a unit. The seat back foam pad was availble seperately, but not the bottom
1986-1989 Frame, Drivers Seat Cushon (with pad)(1986-88 with YR1) (1989 with B20) Part # 20427684
1986-1989 Frame, Passenger Seat Cushon (with pad)(1986-88 with YR1) (1989 with B20) Part # 20427684
90-92 use the same part for the lower cushon..
Hope that helps.
John
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
89mulletbird
Aug 12, 2015 07:08 PM
