repainting,need HELP!!
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
i searched but didn't find the answers to my questions
1. for an '89 does anybody have the exact placement measurements for the door decals,ie. x" from rear door edge,x" from bottom door??
width of stripes black over gold for '89,both same width,black or gold narrower or wider like black 1/2" gold 1/4"??something like that
we've been stripping bumper covers down,ready for flex primer in the morn,plan on reassembling Sat. any help is appreciated!!!
Engine: 355 carb'd
Transmission: 5spd
do i need to
send a email,
https://www.thirdgen.org/techbb2/sho...ment:confused:
Car: 1987 IROC + 1992 RS Convertible + 2001 Z28
Engine: L98 350 + 305 + LS1 350
Transmission: all autos
Does anyone out there have an assembly manual for the 88 thru 90 Camaro. This will give him the measurements he needs. I have one for the 86 Camaro and the 87 Camaro but this is no help since Chevrolrt changed the position of the IROC on the doors and changed the stripe around the bottom. not to mention putting a gap between the stripe. If you can locate the assembly manual though it will give you the exact measurements.
Car: Several
Engine: Several
Transmission: several
finding the information i need??
Engine: 355 carb'd
Transmission: 5spd
yes i have
and only got ******* 87 i think,toward front of door,i'm just gonna try to use them measurement from the rear door edge and use the same vertical??unless someone would like to give the 88-90 placements
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
