steering column
Old Mar 11, 2004 | 11:35 PM
gilley's86's Avatar
Car: 1986 Camaro SC
Engine: 305, AKA 30WHY
steering column
Ok, figured this would be my best shot. I need to replace my steering column in my '86 and I've been told that only certain year columns will be compatable with mine. What years are these. Thanks again.
Gilley
Old Mar 12, 2004 | 11:27 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
as far as fitting, all years should be compatible, the only differences i can think of would be VATS,Airbag, and cruise etc
Old Mar 17, 2004 | 12:09 PM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
Hi all
Not to jack the thread.. Just about any GM column should work?? I have taken mine apart once, and realize I would have to keep my cylinder lock. Should all the harness be a direct fit??
Old Mar 17, 2004 | 11:29 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
i put a 90 column w/air bag into an 82 with no mods.if you need a column i have a 91 tilt w/key for 65.00+ship,sorry no airbag wheel.
Old Mar 18, 2004 | 12:48 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Only those from 84 to 88 will directly bolt and plug in. 89-92 have the VATS to contend with, and the 82 and 83 have different wiring for the windshield wipers which can be changed to work but is a minor PITA.
The only real thing to watch for is the cruise and wiper controls - you need a delay switch to operate a delay motor...cruise should be obvious
Pete
Old Mar 18, 2004 | 09:32 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
no if youre installing it into a non-equipped vats car, then u just leave it unplugged, wont effect the operation of the car, and if your are installing it into a vats equipped car, then u splice the vats wires from the new column to the old wires on the old column
Old Mar 19, 2004 | 07:57 AM
gilley's86's Avatar
Car: 1986 Camaro SC
Hey guys, thanks for all the helpful info. I actually got one out of an 84 bird. Everything was great except, the bird had delay wipers and no cruise where as i have non-delay wiper and cruise, switched my switch out of my old column into the other one, now my high wipers are a click below what it reads, but that a minor insignificance for now. I hooked my cruise back up, but that doesn't work yet either, I guess its just something to work on. Also, the whole reason I put the column in in the first place was to get my blinkers to work. Long story, but I changed to an aftermarket shifter, which ended up breaking the pewter piece in the column cause my lock cable wasn't hooked up correctly. Anyways, everytime I clicked my blinker a blew a fuse. Now, it worked fine until after I started the car. Then I blew a fuse again. So I put a 30 amp in instead of the 20 amp, is this safe? Thanks again. Gilley
Old Mar 19, 2004 | 01:03 PM
Um, no. You need to find out why the fuse kept blowing, and fix that problem. The only thing that the higher rated fuse will do, is allow more power to flow through the wire before it blows again; this could cause the wire to heat up enough that it will melt the insulation off of it, and cause a short-circuit that could result in a fire.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
