87 GTA question
Old Apr 4, 2004 | 02:28 PM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
87 GTA question
My 87 GTA has a nine bolt rearend, did 87 GTA's get those or did someone put that in themselves? It doesn't look like a transplant but I don't know when the nine bolts were used, thats why I am asking. Thanks in advance!
Old Apr 4, 2004 | 02:32 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Its more than likely original.
Old Apr 4, 2004 | 05:06 PM
Ian_F's Avatar
Engine: 4.0
oh cool. Thanks.
Old Apr 4, 2004 | 06:00 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
As specified elsewhere on this site, the 9 bolt was optional on the 1986-1989 F-body cars...
So it probably is original...
Old Apr 4, 2004 | 10:28 PM
Guest
Guest
Posts: n/a
The 9 bolt actually first appeared in 1985.
Old Apr 5, 2004 | 01:01 AM
cdartz's Avatar
Yep, most likely original. If your car is an automatic then your ratio should be 3.27:1.
Old Apr 5, 2004 | 09:55 AM
Engine: LS3
Transmission: 6L80E
Has there ever been anyone on Thirdgen with an original 85 9 bolt? I knew it was optional, but didn't think it was really out there...
Or is it more common than I think? I thought the 86 9 bolts were pretty rare and that it wasn't common until 87...
Old Apr 5, 2004 | 10:02 AM
TTA 1387's Avatar
When I had my 84 HO, a buddy of mine had an 85 HO IROC that had one. Both cars were 5spd.
Old Apr 5, 2004 | 12:09 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
My cousin has a 85 T/a with the B/W 9bolt. His car was a L69 car. The gears are 3:73's.
Laters,
Conrad
Oh, his car is a 5speed also.
Old Apr 5, 2004 | 12:25 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Firebirds were using the 9-bolt rears before the Camaro.
Old Apr 5, 2004 | 01:43 PM
Engine: LS3
Transmission: 6L80E
[QUOTE]Originally posted by twobirds
[B]My cousin has a 85 T/a with the B/W 9bolt. His car was a L69 car. The gears are 3:73's.
Laters,
Conrad
You are sure that it had a 3.73 stock? And not like a 3.70 or something...I thought factory 3.73 was only a 10 bolt deal then. I know that 3.73 BW gears exist now...
Old Apr 5, 2004 | 09:22 PM
Guest
Guest
Posts: n/a
I owned one many moons ago, had the highway gear (2.77?). When I bought the car I had to go and service the thing (you know, oil, coolant, trans fluid, rear diff) and found out the hard way that not too many people had parts for them. Had to order the diff gasket from the dealer.
NinjaNife
Aug 23, 2015 11:49 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
