Any Difference Between 84 and 85 Z28
Old May 9, 2004 | 11:28 PM
Outlaw87's Avatar
Car: 2002 Camaro SS
Engine: LS1 350 V8
Transmission: Automatic 4 Speed
Ok this is starting to bother me... I have been looking at pictures of 84 and 85 Z28s, and they seem to look a little bit different in body style, espically at the back end... but I cant decide if its just the cars im looking at. Do any of you know if their is a difference in body style... I appologize for the inconveince but its just one of those things you cant get out of your head.
Old May 9, 2004 | 11:37 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
Re: Any Difference Between 84 and 85 Z28
search...
they changed the GFX in 85 to a different style among other things. there was a thread not to long ago that had pics of all the different years and differences etc.
Old May 10, 2004 | 07:03 AM
nolanr0413's Avatar
Car: Trans am
the gfx changed, the interiors changed, A bunch of things changed from 84 tp 85, tpi came out in 85 .The car looks better in 85 than it does in 82-84.
Old May 10, 2004 | 03:27 PM
Outlaw87's Avatar
Car: 2002 Camaro SS
Engine: LS1 350 V8
Yeah im begining to see some differences, and I do agree that most 85 looks better... but this 84 looks awesome...
Old May 11, 2004 | 12:29 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
There are big differences between the 2 as already mentioned: ground efx,the nose was changed and the interior somewhat.
Old May 12, 2004 | 01:29 AM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
i got a pre 85 Z28 and i think its just as good or better then 85 Zs
Old May 12, 2004 | 10:53 AM
91Zman's Avatar
Car: 1991 Z28
http://www.bonestockracing.com/z28ho.htm
Old May 12, 2004 | 10:54 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Anyone else notice that 84Z has an 85-90 rear bumper and 1/4 gfx??
I do like the 82-84 Z's, if the color, wheel combo, and ride height is working together.
Old May 12, 2004 | 06:57 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
And you noticed a difference in the rear because the taillights are different. The '85 had two horizontal grids(at least, the IROCs and Zs did--not sure about the other models) instead of one like the '82-'84.
I'm not sure I see what you mean Dante. That body and gfx looks perfectly normal for an '82-'84, except for the blacked-out taillights and no stripes.
Old May 12, 2004 | 09:30 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Look closely, he used an 85-90 rear bumper and rear 1/4 peices instead of the stock 82-84 rear. If you compare the amount of silver on the rear end with the sides/front, you'll see it. Compare it also to another 82-84 Z.
Old May 12, 2004 | 09:41 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
One other way to tell is by the curve (or lack of) on the rear bumper. If you look at the side profiles, an 82-84 has a slight curve/roll look where the back bumper almost curves under the car. The 85-90 rear bumper is more defined and almost forms a corner.
Here's an example:
Old May 13, 2004 | 02:11 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I noticed it also.
The 85-90 GFX were wider than the 82-84. It looks good on this car, but it is not the correct rear bumper cover
Old May 13, 2004 | 06:35 PM
cdartz's Avatar
That just might be the best 84 Z I've ever seen a picture of, and those wheels are awesome. Normally I prefer stock rims to aftermarket, but those look killer on that car. Anyone know who makes them?
Old May 13, 2004 | 10:21 PM
91Zman's Avatar
Car: 1991 Z28
The wheels in the link that I posted they are Fikse FM/5's ,really expensive.Scroll down the link and he tells you more about the car.
Old May 13, 2004 | 10:31 PM
91Zman's Avatar
Car: 1991 Z28
Originally posted by scottmoyer
I noticed it also.
In the link that I provided he says what he updated .
Old May 14, 2004 | 09:48 AM
86transamws6's Avatar
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
Also the hood. The pre 85 Z had indentations in the middle (the crossfires had the flaps that open). The 85-90 Z hood had the louvers, and 91-92 had the same hood as 85-90 but had the blisters bolted in instead of the louvers
Old May 14, 2004 | 09:54 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
'85 is also when they changed the taillights to what I call the checkerboard lights or tic-tac-toe lights with the lines running from top to bottom and left to right.
Old May 16, 2004 | 10:24 PM
David M's Avatar
Car: '84 Z28
Engine: L69
The main difference on the front fascia is that on the '85 cars the park/turn signal lamps aren't near as recessed. The '84 front has much harder angular lines. In '85 it was "softened" up. On the rear fascia there is a recessed area where the "Z28" nameplate goes. I've seen too many '82-'84 Z28's where the Z28 nameplate gets put back on the rear fascia and it's misplaced. Usually all the way over to the right!
Old May 16, 2004 | 11:27 PM
Car: 1983 Z28
Transmission: TH350
dont 4get also the pre 84s hoods are fiberglass
Frozer!!!
Jan 19, 2024 04:55 PM
onefreakz
May 14, 2018 12:15 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
neekolzun
Aug 24, 2015 04:59 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
