Dumb Newbie question
Engine: L98, Hemi 6.2
Made in: United States
Manufacturer: General Motors
Make: Chevrolet
Carline Code: F-Body
Carline Series: Camaro (all models)
Body Type: 2 door coupe (hatchback)
Restraint System: Manual belts (driver inflatable)
Engine Code: 350 ci V8 B2L/L98 (1987-1992)
I is the CHECK DIGIT
Model Year: 1991
Assembly Plant: Van Nuys
Production Sequence: 114024
this is my car vin decoder thing when i typed my vin on thirdgen.org
First of all what they mean production sequence??
And what is a B2L/l98 mean? i kno the L98/ is the 350 TPI but what is a B2L????
Make: Chevrolet
Model Year: 1991
Car: 87 IROC-Z
Transmission: automatic
Your car was the 114024th car built at Van Nuys for the 1991 model year.
B2L is the option package that the L98 is part of. Like J65, and G80 are part of the G92 package
Car: 87 IROC-Z
In 1991 G92 was an option with the 350. So check your SPID sticker in your console if it has G92 on it, you have it, if it doesn't you don't.
hey labart i think its a g92!!!!!!!!!!! on the spid sticker inside the console theres alot of seperate 3 digit numbers.... and theres like a alot anyways i spotted a b2l and then i think the secon last row on the top i spotted G92! does this mean i hav a g92???
AJ3 AM9 AR9 AU3 A31 A90 B18 ((B2L)) 834 B35 B84
Dc4 D34 D35 D42 DSX D8F 081 e52 E92 FE2 GU5
1PC J65 KC4 K34 k68 (L98) M08 MXO NAS NPS N70
QLC T96 Ub3 Un6 UQL U79 ((VAN)) VK3 U73 (Z28) 1A2
19Q 4TU 62W 72W 8NL 82C 821 829 9NL
C49 C60
G80 (((G92)))
N64 N69
ISC 179
hey theres all my numbers from my SPID!
see the B2L and the G92?! Does this mean its a G92?!!! And is it is what did the G92 contaIN?! mINE HAS A/C but i herd some didnt com wit it
C49 C60
G80 (((G92)))
N64 N69
ISC 179
see the B2L and the G92?! Does this mean its a G92?!!! And is it is what did the G92 contaIN?! mINE HAS A/C but i herd some didnt com wit it Supreme Member
Car: 87 IROC-Z
I'm assuming tha what you typed in as E92, was actually G92. But you have GU5 which is the G92 axel ratio for 1991. You don't have option 1LE which is what you got if you didn't order air conditioning.
1LE had better brakes, and a little better suspension, and were somewhat lighter due to less options.
NinjaNife
Aug 23, 2015 11:49 AM
