original or tampered?
Old May 20, 2004 | 09:04 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i just won a 115mph gauge cluster off of ebay. i'm not sure if its original because it has a v6 tach and oil gauge. I know that the gauges would work in a v8 but the tach would read 25% off. i have an autometer tach working properly so i'm not worried about the tach, i just wasn't sure if its original or not? i know v8 models came w/ 60 psi and a 5.5k redline. this has 80 psi and 6k redline.
kinda fishy,what do you think?
http://cgi.ebay.com/ebaymotors/ws/eB...478741348&rd=1[/URL]
Old May 21, 2004 | 06:21 AM
Tobias05's Avatar
ttt
Old May 21, 2004 | 08:04 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think the 115 was the base, I think the only other option was the 145 mph for camaros in 90-92.
John
Old May 21, 2004 | 08:28 AM
Tobias05's Avatar
okfoz,
so if you had a base 89 v6 camaro you could get/it came with a 115mph speedo?
I thought tpi z28s and irocs came w/ the 115 speedo between 87-89 and the 350 iroc could be had w/ a 145?
any body else wanna take a stab at this? feel free to correct me
thanks,
brandon
Old May 22, 2004 | 12:10 PM
okfoz's Avatar
IF the speedos are anything like the Firebird, then:
82-87 85 mph speedo
86-92 140 mph speedo
88-92 120 mph speedo.
I would assume from looking at firebirds that in 1989 the base speedo would have been somewhat similar... could be wrong tho.
I do know that the Camaro retained the cable driven speedo till 1989 or 1990, but the firebird went to a electronic speedo in 1986 EXCEPT for those cars not equiped with the gage package, they got a mech cable speedo.
BTY, what difference would it make if it was tampered or not, since its not originaly from your car, change the speedo and its considered "tampered" by some.
hope that helps
John
Old May 22, 2004 | 12:21 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
....so if you had a base 89 v6 camaro you could get/it came with a 115mph speedo?
Yes. What I saw pictured came from a 1988-1989 V6 Camaro/RS. It did NOT come in an IROC-Z.
Fact (1987):
All speedos were all 85-mph units with a V6 and LG4 V8 regardless of model. With a 305 TPI or 350, the 145-mph speedo was used.
Fact (1988-89):
The 115-mph unit replaced the 85-mph speedo in 1988 as the "base" speedo. All V6 Camaros got the 6,000 rpm redline tach. All 1988-1989 305 TBI IROC-Z's got the 115-mph speedo. All 1988-1989 350 Camaros got the 145-mph speedo.
What I cannot guarantee (1988-89): 305 TPI IROC-Zs>> I do not know if these coupes and convertibles came with the 115 or 145-mph. Furthermore, I do not know if G92 had anything to do with the speedo for these years.
Old May 23, 2004 | 11:39 AM
Tobias05's Avatar
thanks willie and okfoz for answering my questions.
learn something everyday
later,
brandon
Old May 25, 2004 | 12:46 PM
okfoz's Avatar
Willie,
When I was really into finding information on my Formula I went through the parts & illustration catalog for Firebirds, I found the following information:
Notice in 88 & 89 that the rear gear would help determine the speedo/tach combo.
BTY, this is for V8's only.
1987
305 LG4 (4BBL)
Transmission: A4 or M5
Speedometer: 85 mph
Tachometer: 5000red / 6500max
305 LB9 (TPI)
Transmission: A4
Speedometer: 140 mph
305 LB9 (TPI)
Transmission: M5
Tachometer: 5500red / 8000max
350 L98 (B2L) (TPI)
Transmission: A4
1988 & 1989
305 LO3 (TBI)
Rear Gear: All
Speedometer: 120 mph
305 LB9 (TPI)
Transmission: A4
Rear Gear: 2.73 (GU2)
305 LB9 (TPI)
Transmission: M5
Rear Gear: 3.08 (GU4)
305 LB9 (TPI)
Transmission: A4
Rear Gear: 3.23 (GU5) or 3.27 (GW6)
305 LB9 (TPI)
Transmission: M5
Rear Gear: 3.45 (GM3)
350 L98 (B2L)
Transmission: A4
Rear Gear: All
1990 - 1992
305 LO3 (TBI)
Transmission: A4, M5
305 LB9 (TPI)
305 LB9 (TPI)
Transmission: M5
350 L98 (B2L) (TPI)
Transmission: A4
Old Aug 15, 2004 | 04:15 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
well, i dont know if i can help at all, but here are two facts that i have found. 1) my 89 IROC with TPI 305 and 5 speed came FACTORY with the 145 speedo. 2) my 1989 Chevrolet brochure shows the '89 RS with a 115 speedo...dont know if this helps at all
Josh
Old Aug 16, 2004 | 02:34 PM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
my '89 neverbeentouched instrument cluster has a 115mph speedo, 60psi oil gauge, 4500 rpm orange , 5000 rpm red , 6500 rpm max tach. this is a 305 tbi RS convertible.
88rscamar0
Sep 23, 2015 09:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
84 TA NV
Sep 6, 2015 08:02 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
greenyone
Sep 2, 2015 03:39 PM
