trans question
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
trans question
ok the 700r4 is a 3 spd auto with a OD right?
well whats the base trans without the OD unit? someone told me a turbo 350. but im not sure.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The TH700R4 is a 4 speed automatic overdrive transmission. There isn't a base 3 speed version of it. The overdrive feature is integral and can't be separated at all. Some design elements in the 700R4 are supposedly similar to the TH350, but they are different transmissions.
The TH200-4R on the other hand is pretty much a TH200 with an overdrive unit added on.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I thought the 700R was closer in design to the 400 trans than the 350 trans, could be wrong tho... Although this conversation might be better had in the transmission area...
John
John
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The 700R4 is a 4spd overdrive with a lockout torque converter. In the 80's and early 90's GM did not produce a 4spd version of the 400 Turbo until the 4L80E was produced.
The 200R4 was the tranny that was used in the Grand Nationals and Turbo T/A.
There were several versions of the 700R4 (V8, V6 and several versions of the V6 tranny)
The best tranny without the OD would be the 400 Turbo. This was the tranny that GM put behind the large HP engines (and Chevy Big blocks) such as the Buick 455, Pontiac Ram Air 400's and 455's, Caddilac 501's and so on.
There are both short tailshaft and long tailshaft versions of this tranny.
The 350 Turbo is a solid tranny and is actually easier to find than the 400 Turbo and the 350 has a lower 1st gear than the 400. But for rock solid tranny without any modification, the 400 is the better way to go for dependability.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
