RPO Codes
Old Sep 6, 2004 | 09:23 AM
cokeman118
Guest
Posts: n/a
RPO Codes
Hello,
I'm new to this board and I'm new to the F-Body community. I just recently bought a 1982 Trans Am Special Edition. My question is about the RPO codes. As far as I know they were located on the underside of the console lid, however they weren't there on this vehicle. I asked the owner if he knew where they were and he thought they should be there also. He said he saw them somewhere but couldn't find them. I don't know if they were removed at some point or if they are in a different location. If they are nowhere to be found is it possible to find out the RPO codes from Pontiac? Is it possible to get a repo RPO sheet? I really need to know what options are on this car.
Old Sep 6, 2004 | 11:28 AM
aerosmithr0cker's Avatar
Car: 1991 Z28 clone & 1985 Fiero 2M4
Engine: 305 TPI (In Progress, Camaro) & 2.5L 4 cyl soon to be 3.4
Transmission: 700R4 (Camaro) & Isuzu 5 speed (Fiero)
hmm, you can get a copy of the factory invoice and a restoration packet through pontiac historical services but it costs like 40 bucks. do a :Search on invoices and build sheets you should find some info
Old Sep 6, 2004 | 11:38 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On the 1982 models it was known as a "Body Number Plate" and it was a metal plate attached to the front tie bar behind the left headlight in the engine compartment.
Old Sep 6, 2004 | 08:07 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Spend an extra $35 & do this http://www.phs-online.com/
http://www.phs-online.com/order.htm
you will get all the information on it plus more.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
