What year did they use the light blue with grey stripe on bottom For the Formula
Old Oct 11, 2004 | 08:25 PM
The_Bandit's Avatar
Car: 98 Trans Am
Engine: teh LS1 can nevar loose!
What year did they use theblue with grey stripe on bottom For the Formula pics inside
Just like the one you see here
Was that 1990 only? Is that just a decal kit or is it painted on.
here is a red version
Old Oct 14, 2004 | 11:15 AM
Ron79's Avatar
Car: Old man car till I get another 3rd Gen
Engine: at least it's a V8
Transmission: Wrong wheel drive. Makes no difference to me.
I'm not sure of the exact years that color was available, I think it was 87-90. As to the color layout, it is an actual two tone with a decal kit to separate. My 86 Firebird had a similar paint scheme when I bought it, and I was surprised to find out that the decal's primary purpose was to serve as a way to "clean up" the appearance of the break between the two colors since it was not done on a body line. I think that light blue was called Maui Blue?
Old Oct 16, 2004 | 01:13 PM
89formulaguy's Avatar
Car: 89 Formula
Engine: 5.0 Liter TBI
Here are a couple of pics of my 89 Formula. It basically looks just like the one on the thirdgen logo. The decal stripe separating the blue and silver paint is red on top with black underneath which fades to clear.
<img src="http://www.valiantakitas.com/firebird/front.jpg">
<img src="http://www.valiantakitas.com/firebird/side.jpg">
I had an 87 Formula which was black and silver also and the separating stripe was orange and black.
Brian
Old Oct 17, 2004 | 12:10 AM
The_Bandit's Avatar
Car: 98 Trans Am
Brian
wow, i love that car. its my favorite 3rd gen I believe. I want to own one just like that someday. I currently own a 98 Trans Am.
Old Oct 17, 2004 | 01:00 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
Brian
Beautiful car!!:hail: :hail: :hail:
I have the exact same one. Do you have anymore pics you could post?
Old Oct 17, 2004 | 02:05 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
i like that red formula, mine is red/silver but the decal is the same as the blue one.. i like the black stripe alot better
on second look it actually looks like the same decal.. but that picture made it look different.... heh... anyways i think when i get the car repainted ill try a black seperating line like that
Old Oct 17, 2004 | 10:12 PM
Car: 89 Formula
Thanks!! I have many pictures from just about every angle. Just let me know what you want to see in a picture and I can post it.
I love the color. The car is totally original with 77K miles.
Brian
Old Oct 18, 2004 | 07:29 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
That color combo was availble from 1988 thru 1990. The "Maui Blue" was not available in 1987. An interesting fact is in 1987 color #23 was "Bright Blue Metallic", which is a dark Blue. In 1988 color #23 was the "silver blue metallic" aka Maui Blue.
You could special order a Formula or Firebird with stripe delete WX1 It was a credit of about $150.00. But the stripe was standard.
John
Old Oct 18, 2004 | 07:36 AM
okfoz's Avatar
I noticed something about those two Maui Blue Formulas. If you look under the front fender in front of the wheel where the air Dam is one is painted silver and the other is black.
89 Formulaguy & 83firebirdS/E, If you could look at yours and tell me if it is smooth or has a texture??? I suspect that 83firebirdS/E would be smoothe and the 89Formulaguy's will have a texture.
Since there both made in 1989, could you look on your drivers door and tell me what month and year your cars were produced...
Please
John
Old Oct 18, 2004 | 07:22 PM
Car: 89 Formula
Please
John
Mine is black and has a texture to it. I never noticed that the blue Formula Pontiac used in their press kit was painted silver under the nose. I believe my '87 was painted silver. Going to have to look now....
Just looked inside the door and the build month is 01/89 which makes sense because the pricing date on the invoice is 1-27-89 and the shipping date is 2-1-89
Did they change the lower area sometime in 89? Have you found that some 89's have the lower section painted?
Brian
Old Oct 19, 2004 | 06:57 AM
okfoz's Avatar
I am trying to figure out what is "correct" My 87 Formula was originally yellow with the dark gray stripe. Under the front of the car it was painted dark gray, like the stripe (and the panels were smoothe). When I was thinking about making a ram air setup from under the car I picked up an extra passenger side piece, and it had a texture.
I began looking to see if possibly the Formula was painted but the base was not, that did not seem to hold water. Then when I noticed that one car had it painted and the other didn't, in the same year, (in this thread) I am beginning to think that maybe it was a mid year change in 1989...
The Jury is still out, but it is an interesting research project.
John
Old Oct 19, 2004 | 09:26 PM
Car: 89 Formula
Hi John,
Hopefully this picture will help. This is my 87 Formula (R.I.P.). You can clearly see that the underside of the nose is painted silver. This picture was taken when the car was two or three days old.
<img src="http://www.valiantakitas.com/firebird/s87formula.jpg">
I also have pictures of another 87 firebird and an 86. Both have the two tone paint and both have the underside painted.
Hope this helps.
Brian
Old Oct 19, 2004 | 10:47 PM
Actually mine has texture and was black. I however decided to paint it all silver because I like how it looks better. My 1983 S/E is the same body color all the way down and is smooth as well and thats what got me liking it.
Old Oct 20, 2004 | 07:13 AM
okfoz's Avatar
89formulaguy,
could you send me a larger pic of your car for my website???
thanks
okfoz @ usol dot com
Well, I decided to see if there was a part number change... here is what I found:
The deflectors on the 1987 formula had the part number 10020355 (LH) & 10020354 (RH).
Starting in 1988 thru 1990 the deflector part number is 10118488 RH and 10118489 (LH)
John
1992 Trans Am
May 10, 2023 07:19 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Linson
Aug 21, 2015 02:12 PM
AkDrifted
Aug 17, 2015 07:45 PM
Omega
Aug 10, 2015 12:46 PM
