AC Control lighting
Car: 87 IROC-Z, 82 Pace Car
AC Control lighting
I've noticed that the left side of my AC/Heat controller is very dimly lit at night. Does anyone know how many lightbulbs are in the AC controller? All other lights in the car work, even the small light under the center dash vents. I'm hoping someone says there are 2 bulbs in there and 1 might be dead. Thanks.
Car: 1984 Trans Am
Engine: GMPP 350 V8
I can only speak for the Firebirds...but There is one light bulb on the right side of the HVAC controls. That is why it is dim on the left side. One bulb is doing all the work, and its on the right.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
One bulb on the pass side. I swapped in a high-intensity 194. The swap helped, but the effect still leaves something to be desired.
JamesC
JamesC
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The left side of your HVAC controls will always be a bit dim.
I replaced the 194 with an LED replacement. It got a little better, but not by much.
Car: Pair of 92 Z28s
see i dont know how to find out if there are bulbs for certain places...cause i have a few dim spots like where the ciggarette lighter is, rear defrosters, fog lights, power mirrors...i guess those arent suppose to light up?
eightsixseven
Dec 16, 2024 01:50 PM
