1987 5.7 iroc vert
Old Apr 15, 2005 | 03:37 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
1987 5.7 iroc vert
Is this true that there were only 2 iroc convertibles made in 1987 with the 5.7 engine.
http://www.hemmings.com/index.cfm/fu...icle_id/210154
Old Apr 15, 2005 | 03:44 PM
Colin91Z's Avatar
Car: 1991 Camaro Z28
I dont know how much truth there is to that, but i would like to see the vin #. I didn't see one listed, hmmmm....
Old Apr 15, 2005 | 05:56 PM
cdartz's Avatar
There were not any VIN "3" (the 6th digit in the VIN) verts ever with the 350 engine. It seems it's not uncommon to find a VIN "2" vert with a 350, and I'm sure there were far more than 2 of them in 1987. The difference between the two types is a "3" car will be listed as a convertible on your title. A "2" car will not. This has to do with how the car became a convertible in the first place. The generally accepted story is that the "3" cars are considered factory authorized verts while the "2" cars were dealer ordered. The reality is that both went directly from the factory to ASC for conversion. The bottom line is that the car in the above link is very suspicious. They don't post the VIN. If they did that would tell us if it's truly worth anything. If the 6th digit is a 3, and the 8th digit is an 8, then it would truely be a rare car.
Old Apr 15, 2005 | 06:17 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
This car has come up twice before on this board. They appear to be advertising it as factory original. Which it is not. It is a customer converted 87 convertible.
There is something not right about this car. The leather interior is wrong, not stock. The door panels are wrong. No vin No.
A member in the Chicago area should go see the car in person and tell us what the scoop is.
Old Apr 15, 2005 | 09:49 PM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
I put alot of stock in Hemmings Motor News, a very reputable source in print. As a dealer listing, it can't be associated too closely, however, I'd say $25K with 44+ thousand miles....hmmmmm
I got mine under 40K, according to my title, a 1989 Formula with L98 block, for $8,600. That was a few years ago, of course, but I think that 25,000 is about what the converted car sold for new.
I've seen lower mileage cars in the same or lower price range.
A pic of the ASC badge would be good too
Bill
Old Apr 15, 2005 | 11:54 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
So far everything that has been said is completely accurate. What I did was to blow up the only image on the dash emblem. It's definitely not a "20th Anniversary...." map pocket which would indicate it's a "3". That means this emblem must be a "Z28 / IROC-Z" piece with ASC's "Special Edition (number)" under it. But from my very fuzzy blow-up, it looks like the factory "Z28 / IROC-Z" emblem has been removed with ASC's retained. This is proof that this car was a customer / dealer conversion, a "2" car.
Old Apr 17, 2005 | 02:44 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
I agree.. Hemmings isn't a fly-by-night operation. I also have some faith in the claim.
I think if it was technically possible and easy to do, you could probably get a one-off from the factory if you knew the right people or had the right connections.
Old Apr 17, 2005 | 04:06 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
https://www.thirdgen.org/techbb2/sho...hreadid=249358
This post tells the truth of the BS car. That car is not factory if it's a 350 and that all-leather interior was never offered, it's re-covered. We had to do some convincing to some people but all the true facts are there. Also, the 87 IROC-Z people are talking about me looking at and finding in that post is the car I bought after looking almost 5 years for it.
pimprs
Aug 24, 2015 11:20 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 11, 2015 03:17 PM
