L69 - SS vs Z28
Old Apr 19, 2005 | 06:19 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
L69 - SS vs Z28
Maybe someone out there knows the answer to this one.
The L69 in the SS was rated at 180hp/225tq while the same engine in a Z28 was rated at 190hp/240tq. GM shows a different PROM for each car (both with AT and 3.73's). If the ratings are right for each car maybe the PROM's make the difference. Any thoughts?
Larry.
Old Apr 19, 2005 | 06:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A glance at the air cleaner might yield a clue
Old Apr 19, 2005 | 06:38 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Yeh that and maybe the electric fan contributes too. Anybody got an old '85 Z28 L69 PROM they'd like to get rid of? Might be interesting to compare the two.
Old Apr 19, 2005 | 09:17 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Yea, in some models, with the same engine the Camaro had about 5 more HP than the Firebird due to the air cleaner.. The later 350 TPI engines had 235hp in the Camaro and 230 in the Firebird.
The Camaro drew cold air from the front of the hood.. Because of the lower hood line and aerodynamic snout, the 'Bird couldn't do this and instead it had a long plastic duct with two 90 degree bends going to a round cannister tucked inside the engine bay near the right fender.
Old Apr 20, 2005 | 06:50 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I guess I am lost, I did not know there was a SS third Gen
John
Old Apr 20, 2005 | 07:34 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Monte Carlo SS
Old Apr 20, 2005 | 08:10 AM
okfoz's Avatar
ok, I did not read far enough to the left to see his Vehicle information, my bad.
John
Old Apr 26, 2005 | 11:38 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
What would the effect be if you put an L69 prom chip into an LG4 ?
Old Apr 27, 2005 | 07:19 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
one problem you would have is that the LG4 does not have a knock sensor (at least early ones did not). The L69 computer uses this sensor to aide in having a more aggressive timing curve.
Old Apr 27, 2005 | 08:23 AM
okfoz's Avatar
I believe both the 86 & 87 LG4 had the knock sensor. My 87 did for sure.
John
Old Apr 27, 2005 | 10:09 AM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Perhaps Exhaust Size and bents make a difference.
I heard that GM had quoted that was the difference in the HP in the Camaro LS1 and the Corvette LS1.
Later, Garrett
PurelyPMD
May 5, 2016 04:57 PM
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
Night rider327
Oct 13, 2015 01:47 AM
leighgrils
Oct 9, 2015 09:38 PM
