Couple ?s
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
Couple ?s
i got a 88 t/a. i was wondering how rare or not my car is. i got a digital dash, ws6 suspension but no disc brakes. performance sound system. also its the low output LO3 t-5 5spd.
2nd ? is could any1 tell me which grey i have for a interior? i need to order a headliner and theres a couple choices, i just dont wanna get the wrong one
thanks for ur help
thanks for ur help
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Your car is not incredibly unusual, as there is a Blue/Silver one here in Flint for sale, its an 87, with the LG4, but appears to have similar options as yours.
To make sure, check your center console. you should have an RPO of 82B... That would be medium/Dark gray. That is the standard silver/gray color interior for 1988.
John
John
THe RPO sheets are not usually on the LID for firebirds, all of the ones I have seen have been on the passenger side inside center console...
John
John
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Man I don't know about you guys,But thats the first Lo3 5spd combo t/a I have seen with a digital dash.But to bad on your rpo codes to verify that digital dash came with the car from the factory.
Try checking under you front or rear seats you might get lucky and find your build sheet
Good Luck
Good Luck
Car: Trans AM
Engine: 305 TBI LO3
i guess one afternoon ill pull the seats, right now i gotta get a new headliner, power window motors, and fix the beater car
RedLeader289
May 28, 2019 01:47 PM
Linson
Oct 1, 2015 09:50 PM
