gutted iroc updates & pics...
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
just wanted to share my restoration progress with TGO, heres my 85 iroc-z, 90% done... just need a few more things taken out: engine, steering column wire, tank emptied and door guts taken out... ( i messed up and rolled the windows down & unhooked the power and harnessess..)
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
heres more: how do i get this cable off the steering column or out of the firewall so i take out sterring and stuff???
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
and this servo brkt is killing me! i tried wd-40 3 times and still cant get these 2 big bolts out... the wd-40 worked on everything else.... help please...
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
anyone in the pittsburgh, pa area wanna make some extra cash and help me remove this 350 and harness????
image removed. 3 image limit
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, last one, heres all of my wiring harnessess neatly packed in boxes with other parts...
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
aint she a beauty!!??
:image removed. 3 image limit
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
can anyone tell how to roll my windows bk up so i can remove all the internal window parts???? also i need to reach the handles... thanks...
You should just be able to hook up a car battery to the motors. Not sure which pin is pos or negative, but you will figure it out. Just connect the battery ground to one wire and the positive to the other. If it doesn't go the way you want switch em around.
Either that or ground the battery to the frame of the door and touch one pin for up and the other for down...I can't remember but I don't think it will really hurt anyting if you do it the wrong way.
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
are you removing the bolt from the underside? it looks like your wrenching on the top. those are welded in and the bolt goes through from underneath. put your head under the pan you will see.
jeff
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
why are those pics removed!!!!
i wanted some one to c the engine incase anyone was willing to help me remove it!
i wanted some one to c the engine incase anyone was willing to help me remove it! Thread Starter
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
and i thought it was a 3 pic limit per message???? i put a pic on each reply, separatly.....
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I think you can only attached one per message. Got any web space? If not, I can host them briefly for you.
Email me at eacadillac@hotmail.com.
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, ill try to get them all together by this friday and send em to ya, thanks for your help!
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
still dont know why they removed my pics... i've seen hundreds of threads with more than one pic posted per reply.... anyway, thanks man....
ambainb
Apr 25, 2016 09:21 PM
db057
Aug 11, 2015 10:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
