The Wonder Bar - What IROCs had them?
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
I've been trying to do a little searching, and I just want to know exactly how the factory determined which car got a steering brace. Is it all IROC's, or just IROC's with 16 inch wheels? Is it maybe only the 88-90 IROC's with the 16's (not the standard 15's)? It just seems like it's hit and miss for which cars had the wonder bar.
It was only the IROC that they came with, correct?
Would a 91/92 Z28 1LE have the wonder bar as well?
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Every IROC I've looked at has had the wonder bar regardless of 15" or 16" rims or other performance suspension options. If it was an IROC, it had a wonder bar.
Car: 1990 Iroc Z Convertible
Engine: LB9
Although it was supposed to be an Iroc specific part there have been reports of 91 Z28's having factory installed wonderbars. Perhaps it was one of those use up the Leftover parts on the line things and once they were gone that was it.
Car: 4
Engine: 6
Transmission: 5
The IROC-Z was a sub-model, so to speak, of Z28. After Chevrolet decided that more could be accomplished by spending their racing dollars in series where Chevrolets raced other cars instead of racing Chevrolets, they continued to use the chassis parts they had developed on the "main" model, even after they no longer could use the "sub-model" branding stickers they had licensed from the racing organization.
So yes, the 90-92 Z28s (after the IROC contract went away) got them too.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Though I can't answer you question, I can say that my 85 IROC came equipped with the wonderbar.
JamesC
JamesC
Originally posted by demonspeed
Ok, so if ALL IROC's got them, then why do I always see people (especially 85-87) owners asking about where to get them?
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
IROC-Z's were officially the only cars to have them. If 91-92 Z28's have them stock, they're leftover parts.
Axle/Gears: 3.45, 3.27, 3.27
Originally posted by suh weet
My 1991 Z28 1LE doen't have one. It was also an early 1991 model (built Oct/1990).
Lon
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Can Isee a picture of one and can they be added to a 92 RS?
Yes. Here is my version of Steering Brace (aka Wonderbar).
Here is a GM Wonderbar.
Either one will fit your RS. A GM bar has a .75" diameter center bar. Mine is 1" and powder-coated.
Lon Salgren
Top-Down Solutions
Lon Salgren
Top-Down Solutions
TaKe a look. It mounts between the sway bar bushing brackets and the frame. They only came on the IROC's, but a previous owner could have installed one on your car.
Lon
Lon
Car: 1991 Z28 1LE
Engine: LB9
Transmission: WC T-5
Lon, I purchased one of your wonder bars. I just got back from the Power Tour, so I haven't put it on yet. Hopefully it will go on today. I am very pleased with the quality and workmanship of the bar ( and my 1LE sway bar links that I ordered), keep it up!
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
When I installed one on my '83 Z28, it did tighten up the front end considerably, especially over rough stuff, like small potholes, speed bumps, etc.
I installed a factory 34mm hollow swaybar (32mm solid is stock '83 Z28) at the same time though, so I couldn't tell you exactly how much was the swaybar, and how much was the wonderbar. I did notice a difference though.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, hit me up with a PM if anyone needs a wonderbar or 34mm hollow sway bar w/new poly links...
because you know you want that handling!!
ProtoMaster22
Aug 26, 2015 07:50 AM
mustangman65_79
Aug 11, 2015 03:17 PM
