factory glass
Old 06-22-2005, 09:41 PM
kaptinkafeen's Avatar
factory glass
Just wondering, how can you tell if the glass in a THird gen was replaced - does the windsheild have LOF or G.M markings on it?- what about the windows and hatch?
Andrew
Old 06-23-2005, 07:41 AM
okfoz's Avatar
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I know that there wer different companies tham made the T-top Glass, I think LOF and PPG.
As for windshields, however, GM has never made their own glass in the past 40 years or so to my knowledge. If the darker tinted band on top of the windshield has faded to yellow instead of blue then you might have the original glass.
Guardian is definately an aftermarket,
LOF & PPG has been used by GM in the past. I believe LOF made our windshield , unfortunately I do not have access to my 2nd formula right now which I believe has the original glass.
Beyond that there is nothing that would determine wether your windshield is the one from the factory as you could replace it with the OEM one.
John
Old 06-23-2005, 10:17 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
GM was still primarlily using LOF(Libbys Own FORD) back in the 80's. The writing was silk screened on and was typically gray or a silver color. The new LOF windows have more of a printed look writing and its usually black.
If you look closely there are a couple letters which is the date code for the window. I don't remember how to decode them but I found the info on the web a while ago.
Old 06-25-2005, 12:29 PM
All of my windows are LOF - although I am quite positive that the front window has been out at least once, I guess it was replaced by GM, or it was only removed for the bady painting.
Not sure.
I guess if glass is broken under warranty, do/did GM dealers get GM equipment as replacement glass, or did they job it out?
-Andrew
Old 06-25-2005, 12:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Some do their own glass, some don't.
Old 06-27-2005, 07:38 AM
okfoz's Avatar
I would ask around to see who does good glass in your area. A dealer will be your most expensive choice. AVOID anyone who will come to your work and replace it there. Although their work seems ok, They sometimes are hacks and to not do a good job. You are better off taking your car to a glass shop.
Actually if you know someone in the bump and paint industry ask them they should know where would be a good place to get it done. Or just call around to bump and paint places.
John
EDIT: Nevermind I misread a statement I thought he needed new glass...
armybyrd
09-28-2023 12:16 AM
Lbibb
05-05-2016 12:00 AM
IROCTheHouse
Exterior Parts Wanted
10-26-2015 02:35 PM
Reid Fleming
10-10-2015 09:56 PM
SS-EXPRESS
09-28-2015 09:14 AM
Quick Reply: factory glass
