88 z28??
Old Sep 6, 2005 | 07:18 PM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
88 z28??
did chevrolet actually make a z28 in 1988?
from everything ive read they didnt, but a friend of mine has an 88 z28.
we looked up the VIN and everything.
Old Sep 6, 2005 | 07:50 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
The vin is not a sure fire way of telling what the car is.
In 88 all Z28's were Iroc-z's. The Camaro White Book says the Z28 was dropped.
However, I prefer to think of it as the Iroc-z became a manditory option on the z28. Afterall the RPO code is Z28, and it says Z28 with Iroc-z below that on the dash.
A Z28 like say an 85-87, no. It can only be an Iroc-z or a Sport Coupe.
I should add that it could be an RS which were built in 88, but only sold in certain parts of the country.
Old Sep 7, 2005 | 11:12 AM
purpleZ-28's Avatar
yes, it does indeed have the z-28 badge underneath the dash. and it is an 88. i just thought that was rather interesting.
how can you tell if its an RS? check the rpo codes?
Old Sep 7, 2005 | 03:47 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
RPO code sheet for a Z28 should have Z28 on it...
sorry I could not resist.
John
Old Sep 7, 2005 | 05:41 PM
labrat's Avatar
Car: 87 IROC-Z
The White Book doesn't say anything about an RPO code for the RS. So I don't know what it would be.
If your car has an 8 or an F in the eighth digit of the vin, then it is an Iroc-z. If it has an E it's either an Iroc-z or a sport coupe. S and it's a sport coupe.
The bottom line is it's not a Z28, Someone may have changed the dash emblem.
Old Sep 7, 2005 | 07:04 PM
lOnEstArMx250r's Avatar
Car: 1988 camaro
Engine: 305 1988 Iroc z
Transmission: Manual
The camaro im about to get is a 88 and it says z28 iroc z...Ill find out more later..But i belive they did make them. The decals it has on it says z28(right above Port injeted..) then on the door it says iroc-z
Old Sep 7, 2005 | 08:21 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Let's put it differently...
You could get a Z28 or an IROC-Z in years 1985 - 1987. The IROC-Z was a option package (RPO B4Z) on the Z28. In 1988, Chevrolet was downsizing the Camaro lineup. The only options were Sport Coupes and IROC-Zs. The RPO code for the IROC-Z from 1988 - 1990 was Z28 and RPO B4Z was dropped. So, in all actuality, instead of having a Z and an IROC-Z, they were combined into one car. If you went into a dealer to order one, you would pick Z28 on the option order sheet and you would receive an IROC-Z upon delivery. In 1991, the IROC-Z option was discontinued and the Z28 nameplate was resurrected.
Old Sep 7, 2005 | 09:07 PM
Car: 1988 camaro
So ur saying that 88's arnt as good? cuase im about to get one? or did i miss understand you
Old Sep 7, 2005 | 10:16 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
No, you aren't understanding. He is saying that an 88 that is a z28 is also an IROC. All third gens are good, some are just more desirable than others.
Old Sep 8, 2005 | 07:28 AM
okfoz's Avatar
Scott,
I have noticed that some 88-90 IROC's did not get a large door decal, only the small IROC badge on the rocker. What would cause this? Did the person order a Z28 and even though they got an IROC it did not have the decal because of how it was ordered? or am I mistaken and someone had just removed the decal from the car?
JOhn
Old Sep 8, 2005 | 08:28 AM
labrat's Avatar
Car: 87 IROC-Z
decal/stripe delete option, 1988-90. I forget which RPO code it was.
Old Sep 8, 2005 | 09:38 AM
okfoz's Avatar
Probably WX1 That was for the firebirds
John
Old Sep 8, 2005 | 03:04 PM
Car: 1988 camaro
So me having a 88 iroc z z28 is good? im pretty confused here..loll sorry
Old Sep 8, 2005 | 04:02 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
GM just dropped the Z28 theme from 88-90, and made the IROC-Z its own model instead of an option on the Z28. Everybody's 88-90 is a Z28 if you want to look at it that way, since that RPO was still used to identify the top model level on the Camaro just like it was in previous years.
Nobody's 88 is special because it says Z28 somewhere.
Old Sep 8, 2005 | 06:37 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
RPO DX3 - Decal and Stripe Delete - credit of $60
Old Sep 8, 2005 | 07:53 PM
scottmoyer's Avatar
Yeah! What they said.
Old Sep 9, 2005 | 12:00 AM
purpleZ-28's Avatar
bassicly, its the top model. its just a label, it changed from z 28 to iroc.
i think thats lame though, if they downsize a model and do away with it, why keep badging cars like that? oh well
just an off topic question, does it have tpi or tbi?
Old Sep 9, 2005 | 05:43 AM
Car: 1988 camaro
Old Sep 9, 2005 | 08:48 AM
Car: 91 Camaro RS
In 1988 it could have either.
Old Sep 10, 2005 | 01:10 PM
purpleZ-28's Avatar
i was asking if he 88 he might buy had tbi or tpi.
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
