How many different types of iroc rims are there?
Old Sep 15, 2005 | 06:05 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i think there are 3 or 4. there is the flat kind, and the kind that goes in with one big groove. then there is the kind with the smaller grooves within the spokes. are there two kinds of these or are they just different caps or what. i cant tell the difference.
maybe having them next to each other can help. i cant tell what the difference is, but i cant stand the second one and i love the first one. i am waiting for pictures of iroc rims locally, and i dont know which kind they will be. it is from a 1990 if it helps. i know they arent the flat kind.
Old Sep 15, 2005 | 06:28 PM
MNformula350's Avatar
the top one was available on 85-87 Iroc's, the bottom one was available on 88-90 Iroc's and there was also a 15" version of the second one that came on 88-90 Iroc's with the TBI engine.
Old Sep 15, 2005 | 07:00 PM
ZZ4 86 Z28's Avatar
darn, i hope this guy doesnt wanna trade me the newer ones.
Old Sep 16, 2005 | 08:16 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
I have a 1990 IROC with the 15 inch version of the two lines, so I don't think it was only the TBI IROC's. And wasn't TBI only offered in 88 IROC's then it was TPI only for 89-90?
Old Sep 18, 2005 | 07:46 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The 15" IROC wheels & tires were stock 88-90 with the 16" ones being optional RPO N96 at $468 extra cost.
Old Sep 18, 2005 | 08:08 AM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I happen to like the first type of wheel better...
Old Sep 18, 2005 | 08:15 AM
Car: 1988 SC Camaro
Engine: 305 TBI
Old Sep 18, 2005 | 12:47 PM
ZZ4 86 Z28's Avatar
i like the first kind so much better! i want them! but i like mine too, so i think i might keep mine. cant decide!
Old Sep 18, 2005 | 01:25 PM
Car: 1988 SC Camaro
Engine: 305 TBI
I definitely like the first kind better...did they come in 16 inch or just 15 inch? (for the 1st wheel, the one displayed by the red Iroc)
Also, what material is it made of?...Aluminum?
Old Sep 20, 2005 | 10:12 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There were a total of 4 different wheel designs available on IROC-Zs over the years.
From 85-87 they all got the traditional 16" design:
In 88, a 15" wheel was standard. This looked like the wheel found on the 82-84 Z28s, and various year RS Camaros:
The 16" wheel was optional, and looked like this:
In 89, the standard wheel was once again a 15", but it looked just like the 16" version:
In 90, the 16" wheel was the only one available.
Old Sep 22, 2005 | 03:34 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I would say that there are only 3 types of "IROC-Z" rims. 85-87, 88-90 and the 89 15incher. The other is just a regular Camaro rim that was used on very few IROCs. So really its not a IROC specific rim.
Kevin
Old Sep 22, 2005 | 03:46 PM
Jim85IROC's Avatar
What you want to call it is up to you. It doesn't change the fact that it was available on the IROC.
I don't know the particulars of it, but I believe it was different from the 82-87 Z28 wheel in that it didn't have a machined surface on the spokes. I'm not sure about this until I look at some of my hi-res pics at home.
Old Sep 27, 2005 | 01:20 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Kevin
Ahh, maybe so... but they came with Iroc-Z centercaps! (I had them!)
Old Sep 27, 2005 | 01:22 PM
Engine: L98 350 TPI
This is True.
Kevin
Old Feb 13, 2013 | 01:07 PM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
Re: How many different types of iroc rims are there?
What iroc rim is the best for fuel economy ?
16x8 double line. 1988-90
15 double line. 1989
Can u get iroc rims alloy so they will be lighter ?
Old Feb 13, 2013 | 01:22 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Old Feb 13, 2013 | 01:35 PM
KG427KG427's Avatar
Car: 1991 camaro
Originally Posted by Johnny Blaze
Which rim size is better for mpg
15 inch iroc
16x8 iroc
Old Feb 13, 2013 | 01:52 PM
Car: 1971 Camaro
Engine: 427
15 inch iroc
16x8 iroc
I don't think you would see any difference.
Overall tire height will be the same.
Weight difference is minimal.
Driving habits could net a much greater gain.
Old Feb 13, 2013 | 02:57 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Yeah what he said, I mean unless you go with some super heavy steel wheels and huge tires your not going to see much or any MPG change.
Old Feb 13, 2013 | 02:59 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
All IROC wheels are made of an aluminum alloy.
Difference in weight is going to be negligible as far as fuel economy is concerned.
Also this thread is 8 years old.
Old Feb 14, 2013 | 01:20 AM
KG427KG427's Avatar
Car: 1991 camaro
We are adding to it.
So 16x8 or 15 inch ?
Which is better for mpg ?
Old Feb 14, 2013 | 11:58 AM
navy02ws6's Avatar
Like I said...there is going to be NO NOTICEABLE DIFFERENCE in mpg vs. the two wheels. If you're looking for better mpg, look elsewhere. Wheels are not your answer, unless you're comparing say a 14 inch steel wheel to a 26 inch solid chrome wheel.
Old Feb 14, 2013 | 06:55 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Original question has been asked and answered. The new question should have had it's own thread, but it's been asked and answered now too.
colton_carlson
Mar 8, 2019 12:21 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
g.l.mos
Aug 22, 2015 12:02 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
