What are the differences between the Turbo Motor in the TA and the Grand Nationals?
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
What are the differences in the 2 engines?
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
Cylinder heads off transverse 3.o liter FWD engine, pistons (to make up cc difference), individual rocker arms (not shaft mounted like GN's), headers........I think that is about it.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
headers, crossover, down pipe.
Aforementioned fwd heads to make it narrower that regular gn engines for clearance. aforementioned pistons to accomodate head chamber size (cc)
different accessory belt(narrower engine slightly)
Latest turbo(same but latest revision)
16.5 psi vs 14.5 psi boost
GNx intercooler vs stock gn intercooler(more fins yadda yadda)
cross drilled crank
Actually uses a real oil filter :-) lol
Higher psi fuel pressure from the factory(43.5 i think vs. 38 or so)
No rev limiter/fuel cut off 170mph here we come.
Better looking and more aerodynamic car :-)
Frustrates me more than nay turbo car I have ever worked on.
Sure theres other little things too, but tthose are the big ones.
Hit up turbobuick.com TTA board or turbobuicks.com or gnttype.org and the like for more info.
later
Jeremy
cross drilled crank
later
Jeremy
Car: 1971 Camaro
Engine: 427
Thanks. I am considering droping a GN style Turbo 6 into our 1967 Firebird convertible. I figure since it came in a Firebird, it is stock, right?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
anyhoo, on subject:
whats the deal with these heads now? ive always thought they were the same heads as the GNs.....
One of the biggest problems with the GN motor swapover, is that the Trans Am uses a vacumn on the brakes, not like the GN electric. So, a few top end changes for the hoses to work.
Good luck with the changeover, and let us know how it works out! Times, too!
George
George
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Do what i did and drop in a 455 in it. Direct bolt in and lots ot torque. I got the 4 wheel drums too on my 68 one day i will have disc brakes and actual gears not the peg leg 2.53 gears.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
can these rwd heads and individual rocker arms still be purchsaed from GM? i am thinking (real tentative, need funding) of doing a similar swap so,time in the future (someday.....) can they be found on any other vehicle or were they streictly TTA parts?
thanks
-X
thanks
-X
Hit up the junkyards. The heads can be found on 87 and up FWD 3.0 Buick LeSabre engines. I don't know much about the rocker arms, but one can assume that the ones off those heads will more than likely work out.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
To my knowedge Buick did not make a 3.0 V6 engine. The LeSabre only got a 3.8L engine in the late 80's thru current.
BTW, you will need to check the Head casting numbers, as there was a change in 1995 when they went to the Series II 3800.
I am also not sure if the 88? thru 90 3.8 Engine used the same heads as the 91+ 3800.
John
John
Car: 84 Trans Am
thanks
-X
thanks
-X
Axle/Gears: n/a
sweet, one less change to make, i don't plan on letting ac rob my engine of power, and those turbo buick heads look cool
, actualy i guess it's the valve covers that look cool. they have "BUICK" in huge letters with a big turbo symbol (TTA 1387s avitar image) on them. looks sick
, actualy i guess it's the valve covers that look cool. they have "BUICK" in huge letters with a big turbo symbol (TTA 1387s avitar image) on them. looks sick Moderator
, actualy i guess it's the valve covers that look cool. they have "BUICK" in huge letters with a big turbo symbol (TTA 1387s avitar image) on them. looks sick I like the symbol too.
John
evilstuie
Jan 9, 2020 08:29 PM
