camaro door on a firebird
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
Hi , i got a 89 firebird and one of my buddies got 2 third gens camaros (both in pieces) a 85 berlinetta rusted (explitive removed) but with a functional V6 2.8 tpi and the other is a 86 iroc z without a motor ant trans is plan is to tranplant the heart of his 85 into the z . My firebird was once accidented by its original owner : he rubbed all the driver side of the car on a metal fence on I10 (in quebec) the second owner repaired the damaged door with some body filler and a full repaint (white to black) but the door's look still not great so i tought i could use my friend's 85 berlinetta door on my 89 bird . Cause the floor is too rusted but the door are not so bad but it's got a trim on the side it'll just leave holes on the side of the door but i will fill it with some putty . Anyway my question is: Is a camaro door will fit on a firebird .
Thank you
Thank you
Your post was edited to remove language not allowed on these boards. Please refrain from using them and special characters to represent them. As a new member, you should be familiar with the board rules you just agreed to when joining!
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yikes! I got pretty confused reading that mess, but ya the door will fit fine.
I think the inner door handles are different... aren't they?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Then what was with the doors I bought once? Instead of having the standard Camaro square inner handles, it had kinda like a hockey stick for a inner handle...
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Id like to see some pics of this handle you guys are talking about. I had a door off an 89 IROC on my old 82 Trans Am. Everything was identical.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
You know... I just looked all over ebay and cardomain trying to find a Firebird with that handle... and I can't! Seems 82-88 used the exact Camaro plate and handle, and in 89-92 they used the same handle but went with a different plate.
Anyone with the little hockey stick handles please post pics so I know I'm not insane! I just recently junked the doors, so I can't get pix myself.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
