vin number
Old Nov 15, 2005 | 02:12 AM
11secharleybboy's Avatar
Car: 83 ta pace
Engine: small block
Transmission: auto o/d
vin number
having trouble sorting out my vin number have an 83 ta but the 8th number is an S the 7th is a 7 and the 10th is a D all the charts i have found show this to be impossable. this is a daytona 500 pace car the paint ,interior,under hood body plates and workings inside the doors are correct for 1983 model year and as far as i can tell all original sheet metal and 2 tone paint 305 cfi motor and o/d trany red instrument lighting not bulbs and leather recaro seats any help is very welcome as am trying to restore thanks
Old Nov 15, 2005 | 09:46 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
what is the VIN? you gave us a little but not enough to be conclusive.
It should be:
1 - United States
G - GM
2 - Pontiac
A - Seatbelt restraint
W - Trans AM
87 - 2 Door coupe
S - 305 ci V8 LU5 (1983) (Cross Fire)
? - Check Diget
D - 1983
L or N - Van Nuys or Norwood
2 - Pontiac
xxxxx
whats the problem?
Old Nov 15, 2005 | 07:53 PM
Car: 83 ta pace
Engine: small block
thanks okfoz
your decode matches what i have! several other decoders on the net are bogas!!!
do you have any production numbers for hard tops produced as pace cars?
read somewhere only about 160 made thanks again and have a great day
Old Nov 16, 2005 | 11:28 AM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Originally posted by 11secharleybboy
thanks okfoz
WAIT !! You say you have a hardtop top '83 datyona
If you do,Take care of it cause only 2 have surfaced recently.
Try and post pics and data plate info if you can.
Old Nov 16, 2005 | 07:13 PM
Car: 83 ta pace
Engine: small block
3rdgenparts hi
yes i recently traded a 66buick special for a 83 daytona hardtop 97000 miles but it needs a lot of work. 40 mph top speed on delivery gutted the cat and tweaked the valves speedo now pegged before third shift. to be worth taking pics needs new hood, pass fender was told encountered a deer and drivers quarter has some cancer starting. the front seat covers are shot the motor runs but the cam is flat and the bottom end ratteled like mad when i changed the oil, the car drives execelent with no under body rust when i checked it out at a buddys muffler shop. i have been searching for seat covers for the recaro's or some one that can copy them with out selling my first born. i am planing to swap out the 305 for a hot 350 i built a few years ago for a sleeper station wagon and keep the crossfire, hooker shorty headers and custom duals but trash the smog inj system have been wondering if i should keep the old engine for numbers maching car value but need more info on this subject i do not plan on letting this car go it's a keeper and should look like new by spring. any help on locating more research material is greatly apprecatied. have a great day and stay safe chuck
Old Nov 16, 2005 | 07:15 PM
Car: 83 ta pace
Engine: small block
3rdgenpartrs
ps the data plate you wanted it the one on the rad support correct? will check back chuck
Old Nov 17, 2005 | 08:33 AM
On Probation
3rdgenpartrs
Yes that is correct
Old Nov 19, 2005 | 03:45 PM
Car: 83 ta pace
Engine: small block
3rdgenparts i have the plate # for you i'm not sure on decode but will try to match what i have here
D 01B 2FS87 N 211501
604 11L 11U 82ME
A09
Y82 N09 D80
055140 586769
it is very confusing the windshield vin is 1G2AW87S4D211501
i thought the third set of body # should code for a ta
i don't know where to look for more plates no build sheets in seats or kick panels also inspected both doors but car has not had a repaint just some touch up on the pass rear quarter.
still have not found info on if the block # should have a partial match also.
also what to thank okfoz again for the in put
i can use all the help i can get thanks again chuck
Old Nov 19, 2005 | 04:06 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Congrats on your hardtop Daytona.
604 11L 11U 82ME
AQ9
Y82 N09 D80
055140 586769
1G2AW87S4DN211501
Y82 = Daytona
Absence of CC1 = Hardtop
Old Nov 19, 2005 | 04:18 PM
okfoz's Avatar
604 11L 11U 82ME
A09
Y82 N09 D80
055140 586769
D = Model Year = 1983
01B = Build Date = January 1st week
2 = Pontiac
F = F-body
S = Firebird Line
87 = 2 Door coupe
N = Norwood OH
2 = Pontiac
11501 = Body Number
60(4) = Light Sand Gray (Leather?)
11L = Exterior White Lower
11U = Exterior White Upper
82M = Dark Sand Gray Moulding??
E = Paint Type (Enamel)
AQ9 = Articulating Bucket Seats
Y82 = Trans AM
N09 = Locking Filler Door
D80 = Spoiler (deck lid)
John
Old Nov 19, 2005 | 11:08 PM
Car: 83 ta pace
Engine: small block
thanks guys i am getting closer to cracking all the codes still need to find out if i need to save the old engine block
thanks chuck
Old Nov 21, 2005 | 07:39 AM
okfoz's Avatar
If the block is original it will have the folowing:
2DN211501 its found under your altinator, there is a little hog that sticks out and its stamped in there
2 - Pontiac
D - 1983
N - Norwood
2 - Pontiac
11501 - Production #
John
Old Nov 22, 2005 | 01:52 AM
Car: 83 ta pace
Engine: small block
thanks okfoz i will pull the alt. tommorow and take a look found out the rear axle housing was swaped out for an 86 unit the salvage yard paint was a dead giveaway planed to pull the cover and check the ratio so i know what i've got.
thanks for all the help.
p.s. do you know 84L69TA have been trying to get in touch on some parts he has for sale no responce
Old Nov 22, 2005 | 07:25 AM
okfoz's Avatar
Rather than pull the cover, why not simply count the turns??? Not as accurate but it would give you an idea...
A 3.73 gear for example, you would turn the driveshaft approximately 3 and 3/4 turns to get a wheel to turn one time.
John
Old Nov 22, 2005 | 11:03 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
actually on an open diff(if its open) it will have to multiplied x2 since the axles/wheels will turn opposite directions the same distance/amount
Old Nov 22, 2005 | 11:53 AM
Car: 83 ta pace
Engine: small block
john and fast68
i figured it needed the gear lube changed anyway plus wanted to make sure has a posi unit in it, never know what you have when you find salvage markings just checking the brakes found one early caliper and one late one and the late one's e brake is locked up inside and won't adjust
thanks again and have a great turkey day
chuck
Old Nov 22, 2005 | 12:00 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yep yep, i agree
happy turkey!
lol
Old Nov 22, 2005 | 02:47 PM
okfoz's Avatar
If you spin the pinion gear and nothing is touching the wheels, it should not matter, as both wheels should turn at the same speed... IF you stop one wheel from spinning then it would be double...
If that is the case then spin the pinion one time, count the revolutions of each tire, then add them together if different, then devide by 2 to get the ratio...
OR just change the DIFF lube and count the teeth .
John
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
