help chevy truck guy
Old Oct 19, 2005 | 02:23 PM
boatpuller's Avatar
hey i need some help from you camaro guys.i bought a 79 truck with a 87 and up 350 in it{4 bolt valve covers}.i sure would like to pin down the year closer than 87-94.heres some #'s. under alt.vh314954...drivers side bell housing ledge gm57lgsgi...middle ledge of bell housing 14093638. i think v means flint and 57 is 350 any of that other mean anything?or is there a date code on block somewhere else? thanks
Old Oct 19, 2005 | 05:49 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
cant help ya but this is gonna get locked....sorry
matt
Old Oct 19, 2005 | 06:51 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
If it isn't a 350 with the Tuned Port Injection used in the 87 - 92 Camaros or Trans Ams, then it doesn't belong on this board.
The #14093638 is designated as a 350 block used in the cars from 87-92 with VIN #s 6,7 and 8. The f-body used only 8. No other way to narrow it further.
Old Oct 25, 2005 | 11:07 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Technically, it could be a Camaro/Firebird engine...
But who cares? It's a 350, roller cam, one piece rear main seal, centerbolt valve covers. Nothing else to know really...
Old Nov 19, 2005 | 08:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
87-up 5.7L
nice find
details on the 79 truck ?
1/2 ton ? 3/4 ton ?
2wd ? 4x4 ?
pickup ?
dually ?
scottsdale ? custom deluxe?
silverado ?
79 for sure ?
you buy it just to pull engine ?
if so then where is it ?
what trans is in it ?
thanks,
good luck
Old Nov 19, 2005 | 09:18 PM
scottmoyer's Avatar
This isn't a truck board. If you want the truck details, use the PM feature.
Old Nov 21, 2005 | 01:33 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
vh314954
V = Pontiac (MI) Assy Plant
H = 1987 ( You got that correct )
3 = Oldsmobile??? Definately not Chevrolet or Pontiac in 1987 as they all had either 1 for Chevy or 2 for Pontiac.
14954 = Sequence number of the car
Oddly enough, I do not think that in 1987 Olds did not offer a 5.7L in any car, Are you sure its not a 2? that would be a Pontiac.
Actually it should read 2VH214954 if for a Pontac or 1VH11954 for Chevrolet. I think it may be missing a diget, OR the plant ONLY for made 1 car line... What did they make in the Pontac MI Plant in 1987?
gm57lgsgi
GM = Obviously General Motors
57L = 5.7L or 350ci
As for the TPI, it WILL fit any 87-95 Engine block with the center bolt valve covers, the 55-86 SBC's used a different angle bolts for the intake to the heads, although someone could technically machine the 85-86 intake for the later heads. The Vortec heads in 1996-1998 Again used a different bolt pattern and you would need to get a Vortec intake
I think ALL SBC's starting in 1987 got the roller cam... I could be wrong, but I have been told that the block at least has the alotment for them.
I hope that helps
John
Old Nov 22, 2005 | 11:08 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
no not all were roller in 87 up
trucks like my 87 c-10 305 tbi is not a roller
but its got the block with the casting stands and holes in the lifter gallery and all that
but unused
i have the engine hanging out on the hoist right outside right now with the intake removed
block casting 14093627 date casting F288
SGI
5.0L
GM roller was very hit and miss
most of the roler stuff was in the cars only early on
caprices, camaros and such
good luck
Old Nov 22, 2005 | 02:49 PM
okfoz's Avatar
Ok, I was wrong but it has the alotment like I stated?
JOhn
Old Nov 22, 2005 | 06:05 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I looked up SGI. Although I cannot tell you what it was originally used in, I can tell you it was not used on any 87-92 F-body.
jhawkeye
May 25, 2022 06:33 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Kaweh
Aug 19, 2015 07:06 PM
Street Lethal
Aug 14, 2015 08:25 PM
