Rpo Code Help?
Old Dec 6, 2005 | 09:29 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Rpo Code Help?
Hello,
Since the RPO decoder is down I was wondering if any of you could help me dechiper these codes? A few numbers or letters might be wrong but any and all help would be appreciated.
AR9-DO2-LG4-UE8-Z28-AU3-D34-MM5-UP8-1AZ-AO1-O35-M39-UX1-191-A31-D7G-NA5-UO5-19U-E26-D80-NOD-U25-72W-B84-E5Z-N33-U26-72B-E9K-E7Z-N65-U75-7Z1-B94-E9Z-N96-U79-729-B97-FE2-QDZ-VK3-8NL-CC1-GC5-TR9-V73-86P-CD4-GC6-TT4-YE2-85A-C49-GU5-T63-YR1-9NL-C60-J65-T93-YS1-C95-K64-T96-YT9- BC/CC WA-L8555-UE555
Thanks alot for your help.
Old Dec 7, 2005 | 01:48 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i am not going to spend my valuble time doing it for you, but here is alink to a working RPO decoder. http://www.austinthirdgen.org/modules.php?name=RPO
Old Dec 7, 2005 | 10:13 AM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Thank you!
Old Dec 7, 2005 | 10:48 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I guess it should be added that if the decoder returns some without a description you can post them and someone usually will try and decifer them. Unfortunately sometimes there not listed, and the information must be decoded from similar items as it is not relevant to actually repairing the car.
John
Old Dec 7, 2005 | 11:02 AM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Thanks John,
I found most but what is this?
Old Dec 7, 2005 | 12:40 PM
okfoz's Avatar
That is your paint colors, athough it is found in the 3 digit RPOs
BC/CC = Base Coat / Clear Coat
WA = Water Base
L = Lower 8555 color coresponds to RPO 41L or 19L (BLACK)
U =Upper 8555 color coresponds to RPO 41U or 19U (BLACK)
John
Old Dec 7, 2005 | 12:45 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
AHHHHHHHH,
Thanks very much, now one last question if you don't mind? What code tells me if this car has the Iroc package?
Thanks alot for your help John.
Old Dec 7, 2005 | 12:52 PM
okfoz's Avatar
If its an 88 - 90 the IROC and Z28 were the same. I am not sure about this but those years I do not think there is a seperate RPO for IROC...
You would have to have someone that knows more about Camaros than I... I specialize in Formulas
Old Dec 7, 2005 | 03:06 PM
Xophertony's Avatar
Axle/Gears: n/a
wait, so IROCZ and Z28 are different? i thought they were interchangeable? just used differnt names for different years...
in case you can't tell i don't know a whole lot about camaros.... we need scottmoyer. he's a camaro guy right?
Old Dec 7, 2005 | 03:27 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It's an 85.
Old Dec 7, 2005 | 03:46 PM
Xophertony's Avatar
Axle/Gears: n/a
only differnce i can find for the IROCZ' and Z28s in 85 (drivetrain wise) was that the IROCZ had an optional 3.42 rear end gear ratio (if equiped with an LB9 5.0 V8) and the z28 could be had with LB9, but NOT 3.42 rear ratio.
i got this off of the "tech data" section on the main page.
Old Dec 7, 2005 | 06:24 PM
87_CAM_F41's Avatar
is there any that u were not 2 able get? if so, try my site i have around 60 RPO Codes my site
Old Dec 7, 2005 | 06:34 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Did someone call my name?
The IROC-Z was an option package on the 85-87 Z28s. 1985-1987 had both the Z28 and IROC-Z along with other models. In 1988, the IROC-Z replaced the Z28 as the top package. So the 88-90 Z28s were all IROC-Zs. In 1990, the IROC-Z was no longer available and the Z28 returned as the top model.
In all actuality, all IROC-Zs are Z28s. In 1985-1987, to get the IROC-Z package, RPO codes Z28 and B4Z were used. 1988-1990 used only RPO Z28. RPO B4Z was dropped in 1988 since all Z28s were IROC-Zs. Your only options were Sport Coupe and IROC-Z. 85-87 you had sport coupe, berlinetta, Z28, IROC-Z and in 87, the LT.
Old Dec 7, 2005 | 06:39 PM
Xophertony's Avatar
Axle/Gears: n/a
firebirds are much more simple
TRANS AM GTA..............top model 87-92
TRANS AM.....................top model 82-87 offered all years
FORMULA......................87-92. a T/A without being a T/A. all the performance, little luxery. everything you need, nothing you don't
FIREBIRD......................82-92 base. available with standard 4cyl and optional V6 and V8 powerplants
Old Dec 7, 2005 | 06:46 PM
scottmoyer's Avatar
TRANS AM GTA top model 87-92
TRANS AM top model 82-87 offered all years
FORMULA 87-92. a T/A without being a T/A. all the performance, little luxery. everything you need, nothing you don't
FIREBIRD 82-92 base. available with standard 4cyl and optional V6 and V8 powerplants
Camaro was similar:
IROC-Z28......................top model 85-90
Z28...............................top model 82-84, 91-92
Berlinetta/LT.................sport/luxury model. Available with V8 and full luxury items.
Sport Coupe.................Base model 82-88. Available with 4,6 or 8 cyl., no options or fully loaded
RS (replaced SC)...........Base model 89-92. Available in V6 or V8, stripped of fully loaded.
Old Dec 7, 2005 | 06:47 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
OK,
I have the Z28 but not the B4C code, it does have fog lights did only the Irocs in 1985 come with fog lights?
Old Dec 7, 2005 | 06:57 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Guys, thanks for all your help. I did some searching and came up with this. I am sure it is an Iroc right?
....so isnt there a way to differintiate z28 from iroc
"Visually" other than the colors?
First and foremost, third gens are old and it's difficult to tell whether it's original, repainted, restriped, etc. The info we furnish here deals with originality only.
That being said, the answer to your question for 1985-87 model years about visual differences is:
1) Z28's came in more exterior colors than the IROC-Z. So if it's one of those colors that wasn't available on the IROC-Z, it must be a Z28, i.e. 1987 dark blue metallic.
2) Z28's of some colors, bright metallic blue for example, came with a tri-colored blue "Z28" emblems whereas a bright metallic blue IROC-Z's "Z28" emblems were tri-colored silver.
3) Z28's were all painted with silver, gold or charcoal ground effects. IROC-Zs were body color.
4) Z28's came with a four-color stripe. The bottom color was always black with the remaining three being similar shades of silver, gold, gray, red, or blue. Some Z28 exterior color combinations had an optional striping color. For example, a white Z28 with silver rockers came with silver striping with red striping as an option. The IROC-Z striping was two-colored: silver/black, gold/black or red/black (1985 only).
5) The tires/wheels were different.
6) IROC-Zs were all equipped with fog lamps. For the Z28, fog lamps were not an option in 1985. They were a $60 option in 1986. In 1987, they were not available separately but were included of the 1SC Option Package #3.
Pictured is a 1987 bright metallic blue Z28. It is a perfect example of what a Z28 looks like. With a gray or black interior, the rockers were silver and the striping was blue (no silver striping available with this color combo in 1987, only 1985 & 1986).
Old Dec 7, 2005 | 07:01 PM
scottmoyer's Avatar
I may be wrong but I think the fog lights were only available with option package 3 (1SC). I know that is the case in 87, but it might also be true for 85. Your car has some good options, but not 1SC. T96 is the RPO for fog lights and you do have that.
Old Dec 7, 2005 | 07:04 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I do have the T96 in the rpo code, it is on the last line. According to the other post I showed I assumed this was an Iroc, could I be wrong?
Old Dec 7, 2005 | 07:09 PM
scottmoyer's Avatar
One of the best ways to know is to check the door sticker. Z28s came with 215 series 15" rims. IROC-Zs came with 245 series 16" rims.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
According to the code reader I got this rear has the 3:23 gears and all around disc brakes.
Old Dec 7, 2005 | 07:10 PM
scottmoyer's Avatar
No rpo B4Z means no IROC-Z. You have a Z28 there.
Old Dec 7, 2005 | 07:34 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I am so confused, it has the 16" rims and the fog lights. According to what I read from the post I listed earlier it is an Iroc. I will post a pic and let me know if it is or isn't. I also thought only Irocs had one color as this car did?
Old Dec 7, 2005 | 07:45 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I didn't spot a G80 in there either, wasn't the performance rear standard in the Iroc as well?
What I would do is make sure that the VIN on the RPO code list in the console matches the VIN on the car so ensure you have the original RPO list.
It was easier to clone an Iroc from a Z28 than it was to clone a Trans Am from a Firebird, and a GTA from a Trans Am, too many differences between them.
Old Dec 7, 2005 | 08:03 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
According to the owner the vin matches the rpo sheet, and he has stated the car is an Iroc, I have no doubt in believing him and I was wondering if any of you can prove him wrong? I have had many different answers on how to truly tell an Iroc from a Z so how do I know for sure???
Old Dec 7, 2005 | 08:05 PM
Klortho's Avatar
Car: 1987 GTA
That in itself tells you.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
According to the rpo code N96 and ODZ it must be an Iroc right?
Old Dec 7, 2005 | 08:13 PM
Klortho's Avatar
Car: 1987 GTA
There is this one code though
1AZ : Order Modification, Orders Sold (or: CUSTOMER ORDERED VEHICLE)
Could be a special order with the iroc stuff, but no B4Z code
Old Dec 7, 2005 | 09:11 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I just got off the phone with the owner and he once again assured me it is a true Iroc. He also stated that the rpo sheet is 21 years old and yellowing and hard to read so the codes he gave me may need some letter and number adjustment. I am flying 2000 miles next week to pick up the car and driving it back home so wish me luck. The car has a rebuilt 350 with 600 miles on it so I should have no problem.
Thanks for all your help everyone!
Old Dec 7, 2005 | 09:41 PM
Xophertony's Avatar
Axle/Gears: n/a
it's close enough. i don't think anyone will thinc less of you for refering to it as an iroc-z. if i was to call my GTA a formula it might **** a few people off. but your Camaro is a 350, with 16" wheels, irocz badging, a 3.23 rear end... call it what you want to call it, you got a sweet ride
Old Dec 7, 2005 | 09:59 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Thank you very much,
I scored this ride for $1050 from a really sincere guy who ran into a problem with a fire at his house. I would like to think I made out like a bandit but I will let you know when I get her home from a 1900 mile drive. The car has new paint, new crossed drilled rotors on disc brakes all the way around, new supension, new motor, looks like a gem and many other new parts. The interior looks sweet if you like Carmine Red but I can live with it for awhile.
Old Dec 7, 2005 | 10:21 PM
Xophertony's Avatar
Axle/Gears: n/a
ebay? how did you come across it?
Old Dec 7, 2005 | 10:32 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It was for sale here on TGO in the cars for sale forum. The owner has been a member since 2003 but only has 1 post so maybe that is why no one responed.
Old Dec 8, 2005 | 06:39 AM
scottmoyer's Avatar
The picture you posted "looks" like an IROC-Z, but that doesn't make it so. The fact the engine has been replaced and the car was repainted makes it even easier to clone. I did notice QDZ in your RPO codes. QDZ is the code for 245 series 16" wheels, only available on the IROC-Z. I still don't see B4Z though which is the IROC-Z package for the Z28.
Old Dec 8, 2005 | 07:41 AM
okfoz's Avatar
IT was driving me nuts
AR9 AU3 AO1 A31 B26 B84 B9K B94 B97 CC1 CD4 C49 C60
DO2 D34 D35 D7G D80 E5Z E7Z E9Z FE2 GC5 GC6 GU5 J65 K64
LG4 MM5 M39 NA5 NOR N33 N65 N96 QDZ TR9 TT4 T63 T93 T96
UE8 UP8 UX1 UO5 U25 U26 U75 U79 VK3 V73 YE2 YR1 YS1 YT9
Z28 1AZ 191 19U 72W 72B 7Z1 729 8NL 86P 85A 9NL C95
I had to correct some, and there appears to be some missing.
JOhn
Old Dec 8, 2005 | 09:11 AM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Thanks again John,
He wrote down the codes using a flash light after he got off of work and he stated there are probably some wrong and perhaps some missing. Could this help identify it?
Old Dec 8, 2005 | 09:54 AM
okfoz's Avatar
I think he probably missed the IROC code, it appears as tho it is a real IROC, as the Z28 was not availble with the 16" rims to my knowledge.
JOhn
Old Dec 8, 2005 | 11:33 AM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
Fog lights weren't even an option on 85 Z28's, it was Iroc only in 85. Fog lights became an option on 86 and 87 Z28's.
Old Dec 8, 2005 | 04:42 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
JOhn
You right John,
I got a phone call and the B4Z code was infact there. Thanks again for everyones help so I could decode this bad boy.
Old Dec 8, 2005 | 07:25 PM
Xophertony's Avatar
Axle/Gears: n/a
yay its an iroc.... YAY... :::ticker tape:::
Old Dec 20, 2005 | 07:34 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
OK guys,
I got the car home from a long 2000 mile drive this weekend. The car is beautiful, has alot of HP and does need some TLC on the interior but I was able to get it for $850 after all was said and done. now I have a question about the badging. The dash and the rear bumper have the orange/red Z28 badges, but the GFX under the doors have the silver Z28 badges. Did it come this way or were the silver ones just added? Any and all help is always appreciated.
Old Dec 21, 2005 | 06:43 AM
  #42
scottmoyer's Avatar
Sounds like it's correct to me. The dash should be red/orange and the rockers should be grey.
Old Dec 21, 2005 | 07:32 AM
  #43
okfoz's Avatar
I need to find some more $850 deals like that.
John
Old Dec 21, 2005 | 07:04 PM
  #44
Car: 04 Silverado
Engine: 4.8
Transmission: auto
You just saved me money because the auction for red z28 badges is ending in an hour and now that I don't need then I can quit bidding.
Old Dec 23, 2005 | 03:36 PM
  #45
JMJ2003's Avatar
Car: A beater.
Engine: Not enough HP.
Transmission: Automatic... I can't drive a stick!
Is the RPO the same thing as the Service Parts Identification?
I found the SPI clear-quack taped to the center console box cover.
(Clear quack tape - Duct tape... Just clear.)
I used that rpo decoder and here's what I got...
AAA - STANDARD EQUIPMENT
AK1 - DELUXE BELT AND SHOULDER HARNESS
AM9 - SEAT, REAR, SPLIT, BACK, FOLDING
AR9 - SEAT, FRONT BUCKET, EUROPEAN STYLE, PASS DRIVER RECLINE
AU3 - LOCK CONTROL, SIDE DOOR, ELECTRIC
A01 - WINDOW, TINTED, ALL SHADED, W/S
A31 - WINDOW, POWER OPERATED, SIDE
A90 - LOCK CONTROL, REAR COMPARTMENT LID, REMOTE CONTROL ELECTRIC RELEASE
BS1 - INSULATION, ACOUSTICAL PACKAGE
BV8 - ORNAMENTATION, EXTERIOR DOOR HANDLE, LOCK CYLINDER, COLOR
B20 - ORNAMENTATION, INTERIOR, LUXURY TRIM GROUP
B34 - COVERING, FRONT FLOOR MATS CARPETED INSERT
B35 - COVERING, REAR, FLOOR MATS CARPETED INSERT
B48 - TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B84 - ORNAMENTATION, EXTERIOR MOLDING, BODY SIDE
CD4 - WIPER SYSTEM WINDSHIELD, PULSE
C60 - HVAC SYSTEM, AIR CONDITIONER FRONT MANUAL CONTROLS
D03 -D1B PAINT, PROCESS, WATER RINSE
D27 - COVER, REAR COMPARTMENT, TRUNK STOW
D35 - MIRROR, OUTSIDE REAR VIEW
D42 - SHADE, REAR COMPARTMENT SECURITY
D80 - SPOILER, REAR DECK
D92 - STRIPE, EXTERIOR DOOR HANDLE
E5Z - SPEEDOMETER ADAPTER (DELETE)
E6N - SPEEDOMETER ADAPTER (DELETE)
GU4 - AXLE, REAR 3.08 RATIO
J42 - BRAKE SYSTEM, POWER, FRONT DISK, REAR DRUM, ALUMINUM
J50 - BRAKE SYSTEM, POWER
K19 - REACTOR SYSTEM, AIR INJECTION
K34 - CRUISE CONTROL, AUTOMATIC, ELECTRONIC
K64 - ALTERNATOR, 78 AMP
LG4 - ENGINE, GAS, 8 CYL, 5.0L, 4BBL
MD8 - TRANSMISSION, AUTO 4 SPEED, 700R4
MXO - MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NB1 - EMISSION SYSTEM, CLOSED LOOP
NB2 - EMISSION SYSTEM, CALIFORNIA, TIER 0
NP5 - LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N09 - LOCK CONTROL, FUEL FILLER DOOR
N24 - WHEEL, 15X7, ALUMINUM, 5 INCH BOLT CIRCLE
N33 - STEERING COLUMN, TILT TYPE
PB4 - LOCK CONTROL, WHEEL
QHW - TIRE ALL, 205/70R14, WHITE-LETTER
TR9 - LAMP, GROUP
T93 - TAIL & STOP LAMP, SMOKED
UP8 - STEREO RADIO INSTALLMENT PROVISIONS
UT1 - TONE GENERATOR, WARNING
UU7 - RADIO, AM/FM STEREO, CASSETTE, CLOCK ETR
U21 - CLUSTER, INSTRUMENTS, OIL, COOL TEMP, VOLTS, TACHOMETER
U23 - CLUSTER, INSTRUMENTS, TRIM ODOMETER
U25 - LAMP, INTERIOR, RR COMP, COURTESY
U27 - LAMP, INTERIOR, I/P COMP, COURTESY
U29 - LAMP, INTERIOR, I/P, COURTESY
U73 - ANTENNA, FIXED, RADIO
U81 - SPEAKER SYSTEM, RR, DUAL
VAN - ASSEMBLY PLANT, VAN NUYS, CALIFORNIA
VD6 - BUMPER PROVISIONS, FRT, ALUMINUM
VJ9 - CALIFORNIA EMISSIONS REQUIREMENTS
VK3 - LICENSE PLATE, FRONT MOUNTING PACKAGE
V73 - VEHICLE STATEMENT, US/CANADA
WS1 - FIREBIRD PERFORMANCE VALUE PACKAGE #1
WS8 - PRICED ORDER CONFIRMATION, REFERENCE SHEET
w69
YR1 - SEAT, FRONT CUSTOM
YS1 - SEAT, REAR CUSTOM
YT1 - BUILD UP DOOR & QTR
YT9 - OPTION PACKAGE, FISHER FURNISHED PARTS
Y06 - RING GEAR, 9.50 IN, SAGINAW, (S.P.O.)
7uj-
8WA - SPRING, COMPUTER SELECTED, REAR, LEFTHAND
9WA - SPRING, COMPUTER SELECTED, REAR, RIGHTHAND
And there's a coupla of codes that weren't listed and I wasn't even going to try and guess 'em...
Anyways, so is this a good package I guess? I have an 1984 FB S/E... Thanks guys!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
