rare?
rare?
hi everyone. i have a simple question. im looking to buy a 91-92 z28. i want a 305tpi with t-5 tranny with t-tops. does all the 305tpi come with 230hp or is there a special rpo for it? ive been looking online for 1 and i cant find one (cant even find one without ttops).
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Those are G92 cars. That exact combo is one of the most desirable imo, and I've never seen one for sale locally.
that would explain it. i have own a 92 rs with a 305tbi. sold it last year and ive been missing my camaro ever since. i rushed into buying that one and was unhappy with the performance but i loved the car. ive been searching for one all over but havent been able to find one (not on ebay, nor locally).
Car: '72 Chevy Nova
Transmission: TH350
Yeah, you'll be extremely hard pressed to find a 305 TPI (LB9) with a T-5 and T-Tops (CC1) that is also a G92 (has a G80 posi rear end with 3.42 gears and dual cats) car. Especially if it's in good condition. They are possible to find though.
If you were looking for a T-top 5 spd car I'd look into an RS like the one you had, and then putting some money into the motor. Swap the TBI for a carb, put some vortec heads on it and a hotter cam and it'll push 300 hp.
do you think that is the way to go? would it be cheaper to buy a z28 with ttops with a 350 and swap the auto tranny over to a t-56? keep in mind, i wont be doing the work myself (im not that mechanically inclined to be doing all that stuff myself).
Car: '72 Chevy Nova
Transmission: TH350
The swap isn't that hard, and it's probably the same price whether you swap an engine or a transmission. Since I'm doing all the work on my own cars myself I'm looking for one that's already a stick, since I'd rather swap a motor.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Actually you will have better luck finding a Formula or GTA with what you want. As they usually had the performance options standard on the 350 and 305/M5
Car: 2011 Ranger
Engine: 2.3L
Transmission: Stick - Shift like a man!
On behalf of the Firebird guys, I say "It's alright that you have terrible taste in cars"
I'm kidding man, calm down
Like has been said tho, find a M5 T-Top car, and swap in a 350. Easiest way possible.
Like has been said tho, find a M5 T-Top car, and swap in a 350. Easiest way possible. Unless you are looking for something that has been modified in its past, you won't find a factory Z with t-tops and the 5spd....Never made them. I think there is a sticky all about the 350cid 5spd, t-top availablitlity with dirvetrain option etc, etc.. in this is forum
-Andrew
-Andrew
In '91-'92? In a Z28? I thought that 5-spd cars came only in hard tops, just like the 350's.
I'm not sure about an RS though.
Scott, where did you get that info from? Curious...As I look through the camaro white book option CC1 is recorded as "not available with RPO G92 performace axle. or with Z28Coupe with 5-speed manual transmission" (p.124) I guess literature can be wrong, but..... And when I went to buy a new '91 from a dealer, I was not permitted to order a 5spd with t-roofs.
-Andrew
-Andrew
Not 100% on 1991, but in 1992, you could get ttops with a 5 speed as long as it wasn't part of the G92 package or option package 3 with a 5 speed. The base Z28 came with a 5 speed and 305. Adding ttops was just an option. I don't know why package 3 restricted the ttops. It added only twin remote mirrors and power seats.
So in summary, ttops were available with 5 speed only when G92 wasn't ordered. Also available only with option package 1 and 2.
sjorgens
Oct 1, 2015 07:54 PM
