Factory 350 with four bolt mains
I have a small problem and am turning to people who I think can help... I am trying to find out if the 3rd gen Camaro or Firebird ever came from the factory with four bolt mains. Even specialty productions like the Police B4C. I know that the Corvette L98 was in a special Trans-Am in '91 or '92. Any help and info or giving me alocation to get concrete info would be greatly appreciated.
Thanks...
[This message has been edited by arthur (edited January 31, 2001).]
Thanks...
The only 4 bolt blocks in a third gen that I'm aware of were a few "warranty" engines. I've heard that the warranty engines were 4 bolts for some reason. I'm sure somebody will correct me if I'm wrong or can give you more details. Later
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
Thanks for the info Jay. Does anybody know where I can find this info with a more concrete background? I need to get documents to support or info from GM or something because this is to satisfy the rulebook for autocross classes. Any assistance is appreciated. Thanks...
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
why do you need GM documentation for a 4 bolt block in a stock 3rd gen for auto-x? just wondering. You might want to look for 91-92 Pontiac Firehawk documentation, im pretty sure that they would have 4-bolts if any 3rd gen had them. Hope that helps
Car: 1991 Formula Firehawk (Clone)
Engine: 350 with Firehawk Package
the 1991-1992 Firehawks (RPO B4U) came with 4-bolt main blocks that were installed by SLP. They were actually pre-1987 truck blocks with SPO L98 aluminum heads.
Here's a list of 4 bolt GM small blocks:
68-69 302 (Camaro Z28)
69 and up 350 Truck engines
69-72 350 LT1 (Camaro Z28; Corvette)
It's actually better to get machine shops to install some holes for 4 bolt mains because they can make them at an angle which makes them stronger.
In addition to the above list of four bolt main small blocks, I have personally built several four-bolt main engines from 1970 (and I have seen a few from '69) 300-horse 350s, most commonly in Impalas, Caprices, Camaros, Corvettes, Chevelles, etc.
Look for 4 barrel Quadrajet carb, dual exhaust and the 300 horse sticker. If it is original, it most likely is a 4-bolt main.
Another surprise in the 300-horse 350 is many times you will find the 'camel hump' or 'double hump' heads with the accessory bolt holes in the ends.
Many a STRONG engine have been built out of 300-horse 350s. The earlier four-bolt main blocks were much stronger (better and more material) than the mid-seventies and later versions (even the truck blocks). Grandma's old Impala can be hiding 500 horses!
jms
jms
ambainb
Apr 25, 2016 09:21 PM
