Q-jet matched with a 700r4 what years?
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
I am in need of the proper throttle arm for a q-jet matched with a 700r4 since i will be changing to carb soon and need this piece so trans will function mormally. Can anyone narrow my search down to which years had this combomation. Thanks
91 Firebird 305/TBI - cam:.420/.442 204/214 - Hooker 1 5/8" headers - TFX PaceSetter Cat-Back - 3.42's Auburn Pro Posi - ASCD Ram-Air hood - Polished Formula Wheels w/Futura's - Open element - .5" Corian TB spacer - Lakewood LCA's - Hotchkis Lowering Springs - KYB Struts/Shocks - 14.78 @ 97.5 mph(G-Tech) - MacEwen MotorSports Whiteface Overlays - 412ci sb waiting to go in this spring.
My Homepage
My Homepage
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The 700R4 transmission has been used in thirdgens since 83, so anything from a carb'd 85-87 should work.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: `86 SS / `87 SS
Even a Q-jet from a TH200, TH250, or TH350 equipped car will work. The crank lever on the carb is the same.
GM interchangability rules. You don't need a 700-R4 car carb for it to work.
Car: 1991 Firebird
Engine: 412ci/sb
Where can I find one of these crank levers anybody got one laying around...I quess I will start looking in the local junkyards.
It looks to be kinda held on the throttle shaft & then the shaft is mooshed over it.
Anything 81-90 should have the right one. Probably 79 & 80 & others too.
What the heck didja end up with, a manual trannied Q-jet?
Might be easier to swap the base...
Car: 1991 Firebird
Engine: 412ci/sb
jmd, I the Q-jet I have is a manual model. Unfortunately, I figure it can't be to hard to switch over to an automatic model. I got a steal on the carb so I am trying to make this one work.
[This message has been edited by Josh91Bird (edited February 28, 2001).]
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
the q-jets used on auto transmission cars have an additional vacuum pot at the rear on the passenger side. it helps shut the back of the carb. down when you suddenly release the gas pedal. according to the books a bad (or missing) pot would cause severe flooding problems. Don't know this from experience, just read it while researching some other q-jet problems.
Z's r Best
Z's r Best
Thornburg
Aug 25, 2015 01:46 AM
