rpo decoding
Old Jan 30, 2006 | 05:23 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
rpo decoding
Hows it going guys, i ended up downloading and rpo decoder not long ago and finally started punching mine in to tonight and i'd like to hear your responses because, most of this means nada to me, i'm pretty sure i've got a *same old same old* camaro in my hands but, would like to hear everyones opinions.
I did notice 1 thing, it does have the f41 handeling package which i beleive was the more performance oriented package (could be wrong here), anyways what do most of these codes read.
I also ended up getting a couple non decoded rpo's which i'd like to know what they are if any of you know.
1: AJ3 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
2: AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
3: AU3 : LOCK CONTROL, SIDE DR, ELEC
4: A31 : WINDOW, POWER OPERATED, SIDE
5: A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
6: B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
7: B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
8: B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
9: CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
10: C49 : DEFOGGER, RR WINDOW, ELECTRIC
11: C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
12: DC4 : MIRROR I/S, R/V, TILT, DUAL READING LAMPS
13: D3W : GEAR, SPEEDO DRIVEN
14: D35 : MIRROR, OUTSIDE REAR VIEW
15: D42 : SHADE, RR COMPT SECURITY
16: D8N : SENSOR, VEH SPD
17: D80 : SPOILER, RR END PNL
18: E5Z : SPEEDOMETER ADAPTER (DELETE)
19: E9Z : SPEEDOMETER KEY (DELETE)
20: F41 : SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
21: GU2 : AXLE REAR, 2.73 RATIO
22: IPB is not in the Data Base
23: J41 : BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
24: K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
25: K68 : GENERATOR,105 AMP
26: L03 : 5.0 LITER V-8 TBI ENGINE
27: MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
28: MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
29: NA5 : EMISSION SYSTEM, FEDERAL, TIER O
30: NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
31: N96 : WHEEL, 16 X 8, CAST ALUMINUM
32: QMT : TIRE ALL, P235/55R16/N BL R/PE ST TL AL2
33: R8T is not in the Data Base
34: UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
35: UN6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
36: UQ1 : RADIO PROVISIONS, FOR STEREO
37: U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
38: VAN : ASSEMBLY PLANT, VAN NUYS, CA
39: VK3 : LICENSE PLATE, FRT MOUNTING PKG
40: V73 : ANTENNA, FIXED
41: Y86 : MERCHANDISED PKG, CAMARO RS
42: 1AY : 1AY: Stock Orders Processing Option (DEALER ORDERED CAR)
43: 1SC : PACKAGE, OPTION 03
44: 15C : TRIM C0MBINATION, CLOTH, MED SLATE GRAY (C) (91)
45: 1SZ : ???
46: 6XU : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
47: 7XU : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
48: 8NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
49: 80Q : MOLDING COLOR, MED QUASAR BLUE MET (91)
50: 80U : PRIMARY COLOR, EXTERIOR, MED QUASAR BLUE MET (91)
51: 82B : TRIM COMBINATION, CLOTH, MED DK GRAY (91)
52: 82I : INTERIOR TRIM, MED DK GRAY (91)
53: 829 : SEAT BELT COLOR, MED DK GRAY (91)
54: 84P : WHEEL COLOR GRAY (91)
55: 9NL : COMPUTER SELECTED REAR RIGHTHAND SPRING
Old Jan 30, 2006 | 10:14 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
where did you get the decoder?I have a 92 also i would like to decode?
Old Jan 31, 2006 | 09:14 AM
Drew's Avatar
You can decode your rpo's right here on the main page... Funny, I just checked the link on the main page and it doesn't work. LOL
F41 was the mid-level suspension, FE2 was the high level, FE1 was the base. However, F41 was standard on most V8 cars. It's also not unusual on V6's or base model cars.
Sounds like a Camaro to me.
Old Feb 1, 2006 | 05:58 AM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
thats kool with me just curious. I downloaded it from somewhere, can't remeber where, someone must know..... I'd send it to you but, hotmail doesn't let me send these sorta files.
Elephantismo
Feb 13, 2019 12:51 AM
AussieZ28
Sep 30, 2015 03:36 PM
F-body-fan
Sep 24, 2015 08:29 AM
iroczguy86
Sep 23, 2015 01:19 PM
64Chief
Sep 12, 2015 08:05 AM
