Why do Z/28's weigh more that RS's?
Old Jun 15, 2001 | 06:03 PM
Intense92's Avatar
I was just reading in the tech section and saw that Z/28's weigh 168 lb's. more than RS's, does anyone know why?
92 Camaro RS 5.0 5-Speed
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
14" open air cleaner
Old Jun 15, 2001 | 08:41 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's not an exact science. A car's weight will vary slightly depending on how it's optioned. If both cars are optioned identically, they should weigh the same. The TPI setup on the Z28 wouldn't add that much weight. I believe that the RS was available with the same upgraded interior that the Z28 was available with, so I think it boiled down to a difference in how the two were optioned.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 15, 2001 | 09:57 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
It was probably because the RS came with the V6. If you add the weight for the V8 option, it should be pretty close to the same.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Jun 15, 2001 | 10:52 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Normally, published curb weights are the base curb weights for that model. Therefore, the ones here are probably for a base, V6 RS vs a base V8 Z28.
Jason E
'89 Camaro RS
Medium Grey Metallic
2.8, A4, T-tops, 91k miles
'97 Z28 w/30th Anniversary package
LT1, M6, t-tops
White with orange stripes, killer system, 42k miles
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Old Jun 19, 2001 | 08:36 PM
85 - LG4's Avatar
Z28's weigh more because they have more aero cladding. This is also why Mustang LX's always beat the GT's.
Old Jun 20, 2001 | 02:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, the RS has the same ground effects as the Z28.
Old Jun 20, 2001 | 02:44 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The weight factor has a lot to do with the options that came on a car. Z28s tended to have more options than the RS, hence the greater weight. That is why GTAs tend to be the heaviest of F-bodies because they came with the most options stock. The Formulas tend to be the lightest due to their "sparse" nature.
Also, things like "sound deadening" can add to the weight. And DO NOT compare a V6 to a V8 car.
Old Jun 22, 2001 | 09:05 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Z28's had thicker swaybars, therefore heavier. Also they has some extra bracing in the engine bay, one piece from the cowl to passenger side hood hinge and one from the passenger side strut tower to the pass side sub frame. No, it probably does not add up to 168 lbs. I'd imagine the 16" rims are heavier than say V6 15" rims. Plus slight larger tire size. A top of the line interior will weight more than the base interior (better seats, more padding, more weight).
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
fbodyfreakls1
Oct 6, 2015 06:34 PM
69 Six Pack
Oct 5, 2015 07:51 PM
1LE91
Aug 31, 2015 08:13 PM
