VSS RPO Code
Old Oct 5, 2001 | 11:12 PM
Blue91''s Avatar
VSS RPO Code
Does anyone know the correct VSS RPO code for a 305 TBI / 5-speed Camaro RS 90-92 ? Ive been trying to find out with no luck, even the dealership couldnt tell me and they list a few of them. My car was originally an auto.The rpo decoder on heredont tell which is which either.
Old Oct 7, 2001 | 08:28 AM
Blue91''s Avatar
Anyone???? It should be a 3 Character code starting with D8?
Old Oct 7, 2001 | 07:09 PM
82RECAROTA's Avatar
Old Oct 7, 2001 | 07:25 PM
Blue91''s Avatar
D8E Is for an automatic, I need the V8 TBI 5-speed code or part number for the 5- speed
Old Oct 7, 2001 | 09:32 PM
82RECAROTA's Avatar
Old Oct 8, 2001 | 03:23 PM
Drew's Avatar
Your in for some fun. There are really only about 3 VSS senders to choose from. It really only matters which gears you have.
Old Oct 8, 2001 | 04:41 PM
Blue91''s Avatar
I really appreciate the replys!! This is a F**king nightmare to find this sensor!!! 3 different dealerships and 4 auto parts stores and no one has a description of what which sensor/p# goes to what!!! This is the deal , I have a 91RS 305TBI (Originally an automatic)now a 5-Speed. My orig.auto speed sensor code was D8E P#10456088. I need the part# or code for the v8 RS with a 5-speed.I was told there is one for TPI and another for TBI. Now im being told it has to do with ratio. I was told the speedo gears were the only difference as far as different ratios were concerned!!!Could someone please clear this up? Are there two different types of sensors, one for TPI and one for TBI , or do they both use the same sensor.Doing the 5-speed conversion was a snap, finding the correct speed sensor , now thats the hard part!!!I also installed 3.42 gears if that makes a difference.
[This message has been edited by Blue91' (edited October 08, 2001).]
Old Oct 8, 2001 | 09:13 PM
jmon92conv's Avatar
Good luck, when I switched gears to teh 3.42's I had to change the speedo gears, not the speed sensor. One quick note, I had to change both gears a real PITA. I had 3.08's if this helps
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old Oct 9, 2001 | 12:16 PM
Drew's Avatar
Here's the deal, no parts store or dealership will be able to help you with this. I have no knowledge of how the 5 spd relates but here's what I know in relation to the auto. There are multiple RPO codes, but there are really only 3 VSS part numbers. The only difference as far as I can tell are the gear ratios of the rearend. The VSS keys off the tailshaft of the tranny, so the only thing it would have to compensate for are different gear ratios.
So you would use whatever sensor your car had originally. If the VSS in the 5 spd is physically different then the auto, you're on your own, if not use the sensor from your original tranny.
Old Oct 9, 2001 | 12:18 PM
Drew's Avatar
Another thing you can try, find a 5spd car with the same differential gear ratio and use that cars VSS rpo.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
