rust issue please help
Old Apr 22, 2006 | 09:04 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
i have a 87 iroc camaro which is a t-top car it has alot of rust where the a pillar tops are heres a pic . the red boxes are where its rusted how would i fix this problem of mine? todays a rainy day so ill take some better pc tomorw but at least you can get an idea. the rust is pretty bad
any help is greatly apreshated
Old Apr 22, 2006 | 11:11 PM
Staged84's Avatar
Car: 84 Z28
Engine: L69
Transmission: 5 speed
I would check out eastwoodco.com. They have pretty much anything you need for rust prevention or repair. I have used their Rust Encapsulator on rusted surfaces for years and have been very satisfied. And if you have any small rust holes you can patch them with their Metal to Metal. It's kind of like aluminum body filler. It's hard as a rock and really bonds to the metal your using it on. It can even be drilled and tapped. I had a 68 Charger with the rear window opening really rusted out in the bottom corners. I used Metal to Metal to basically build the sections that weren't there. It really depends on how big the hole(s) are and where it is on the car. Obviously, if you are rusted through very badly nothing but new metal welded in will suffice. I can't really see how bad your problem is, but maybe this will get you pointed in the right direction.
Old Apr 23, 2006 | 12:54 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
thank you for takingthe time to read this and it is pointing me in the right direction its deep but not that deep like i said im going to take a pic in the morning of it close up
thanks againman
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
jimmy harris
Aug 31, 2015 03:09 PM
hemicudakidd
Aug 31, 2015 06:23 AM
Leggman1
Aug 6, 2015 04:15 AM
