"Restore" engine oil treatment
Old Apr 24, 2006 | 03:32 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
Ive heard hype that this stuff actually works since its not like that useless slick 50 with that micro teflon that just gets filtered out
has anyone noticed there engine run a lil better with this treatment?
its that blue oil in the sliver tin can
Old Apr 24, 2006 | 04:19 PM
HotRodLarry's Avatar
Car: '83 Z28
I put some in a F*rd straight six and noticed an improvement, but I also gave the engine a tune-up and an oil change as well, so it's hard to say if ti worked or not. I heard about one guy that put a little bit in his air compressor and about a week later it was running like new.
Old May 10, 2006 | 07:13 PM
EMTGuzman's Avatar
Car: 05 Grand Prix / 85 Trans Am
Engine: 305 TPI Bored .030/Cam
Transmission: 700R4 Megashifter
i've used it... i love it... used it in a 2000 jeep wrangler in 2005 and it improved gas mileage and acceleration... just put it in my trans am and i'm JUST now getting out of that 500 mile grace period but the car seems to be running a lot better... sounds more like my cam working than gunked up engine internals lol
all i can say is i'll keep using it...
Old May 10, 2006 | 08:32 PM
rgriffin_3's Avatar
my teacher at school says it is not good to use. I guess it is very thick and sludgy. I believe it also affects oil to flow up to the valve train.
Old May 11, 2006 | 03:19 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
I think it works amazing because I put some in a beat to death silverado that would smoke under WOT so bad you couldnt even see, and after we put restore in it didnt smoke for over a month. Its not a permanent fix and The engine finally went. It did help for a while and I would recommend it
Old May 26, 2006 | 03:51 AM
Car: 1985 TransAm
Engine: 5.0L TPI
i agree its not a cure all im just worried of engine damaged im getting mixed opinions
Old Jun 3, 2006 | 12:43 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Anything like that is a bandaid...it will possibly dimisnish the symptoms of a worn motor for a short while but won't help anything really in the long run. Like extremly thick oil used to hide and motor or valvetrain noise...
Old Jun 3, 2006 | 11:42 AM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
I used it in my mazda truck that had 240,000 on it. it stopped it from using oil. It is just like the no slip for transmissions. it will help get a little more life out of it.
Old Jun 3, 2006 | 10:09 PM
cdartz's Avatar
Dude Engine Restore is for high mileage engines, not new engines with only 500 miles. The concept is that it helps old rings seal better to worn cylinder walls. Why on earth would you put it in a new engine?
Old Jun 8, 2006 | 01:13 AM
92GTA's Avatar
The can says you notice a difference after 500 miles. that's what he was refering to. I also think it's great stuff!
Old Jun 20, 2006 | 10:52 AM
pheonixofdoom's Avatar
Car: 1995 Z28
Engine: 355 LT1
used it... no difference at first but now the car definetly runs better...
Old Jun 20, 2006 | 01:06 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
yikes!!!
Old Jun 17, 2009 | 12:13 PM
jkmj999's Avatar
Car: 91 Chevy Camaro z28
Transmission: auto
Re: "Restore" engine oil treatment
Restore engine oil treatment does work . used restore with my last 2 oil change . my 91 z 28 engine with 120,000 miles got it's roar back.
Old Jun 17, 2009 | 12:37 PM
Stephen's Avatar
Car: 87 GTA
Way cool....Your first post is a 3-yr old resurrection!
I use it once a year for my 87 GTA which now uses NO oil & the smoke at start up, stopped after the first time I put it in (at 170,000 miles), after about a month. And my L89 still gets 21 mpg at 200,000 miles!
Old Jun 17, 2009 | 04:17 PM
jkmj999's Avatar
Transmission: auto
awesome car you got there . my 1st was a 79 firebird Formula. with a 6.6 litre , ... missing it everyday.
Old Jun 17, 2009 | 08:19 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Do you have to use it every time you do an oil change or do you use it once in a while?
John
Old Jun 17, 2009 | 08:31 PM
Stephen's Avatar
Car: 87 GTA
John
HAVE to? I dunno.
I do it once a year "just because". I don't see it hurting anything but my cost of the oil change, so.......
Restore FAQs
Old Jun 18, 2009 | 12:40 AM
jkmj999's Avatar
Transmission: auto
i actually used Restore couple of time before oil change also, it's only been about 2 months when i started to use this stuff.. it does make a difference .
Old Jun 18, 2009 | 07:10 AM
86sdubzzT/A's Avatar
Car: 1986 T/A
Axle/Gears: Stock
Whats better?
Lucas or Restore? I always thought the Lucas product(s) to be superior?
Old Jun 18, 2009 | 07:33 PM
jkmj999's Avatar
Transmission: auto
i only used Lucas (stop leak and conditioning) for my auto Transmission just once . some improvement smoother shifting during drive. but Restore does make a noticeable difference on high mileage car. ..
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
