Stock 88 RS
Old Apr 28, 2006 | 05:12 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Stock 88 RS
Just wondering if my rear had posi or not. I cant find my rear end tag and the search failed me Thanks!
Old Apr 28, 2006 | 10:17 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
The easiest way to tell, is to jack up the rear tires. With the trans in neutral and the brake off (preferably on level ground), rotate one tire. If the tires rotate in the same direction, it's a limited slip(posi). If they rotate in the oposite direction, it's a standard differential.
The rear end "tag" is actually stamped on the passenger side, towards the front, of the axle housing. You may have to get some spray cleaner and maybe a wire brush to actually see it. It gives the gear ratio, build date, assy plant, and work shift.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
