Car Manufacturing date?
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
if your car is an 1982-1984 you have "trim tag" above the radiator.
https://www.thirdgen.org/forums/at...g?d=1133406244
At the top left is a 3 digit code. On attached it is 05E. Here is how to decode it.
Build Date - digit 1 & 2 identify month, 3rd digit identifies week.
Month code: 01 = Jan, 02 = Feb, 03 = Mar, 04 = Apr, 05 = May, 06 = Jun, 07 = Jul, 08 = Aug, 09 = Sep, 10 = Oct, 11 = Nov, 12 = Dec
Week code: A = 1st, B = 2nd, C = 3rd, D = 4th, E = 5th
Originally Posted by Bane
Is there a place to go on the web that can tell you the date your car was manufactured using the vin?
Just in case you arent familiar with what each number in the code means here are two good links.
http://www.autoinsurancetips.com/camaro_vin.htm
http://www.autoinsurancetips.com/firebird_vin.htm
Linson
Aug 21, 2015 02:12 PM
