1986 IROC
Old Aug 28, 2006 | 10:22 PM
cmn8989's Avatar
1986 IROC
Hey guys what engines were available on an 1986 IROC, im about to purchase this vehicle. The owner said that its the 5.0 305, I hope to hell its the 215hp one, not the 145 (I dont think they would put that in an IROC)
1986 Camaro IROC Z28
Old Aug 29, 2006 | 01:05 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Sorry but the engine is probably not the 215 hp TPI version, If its the original motor. The 86 Iroc came with either a lame 155 horsepower carbureted LG4 or a 195 horsepower TPI motor. The 85 TPI motor came with an aggresive cam which made more power. A good hint is to look at the rpm tachometer on the guages. If it has a yellow line at 4,500 rpm's... its the lame 305 TPI motor. But if You see a yellow line at 5,000 rpm's and the redline is marked at 5,500 rpm's, You've got the better motor. But I definitely assume that You have the weaker motor with an 86 model.. But the smaller cammed motor makes more low end torque so it's kinda fun to drive. Lemme know what You find if You need more help...
Old Aug 29, 2006 | 05:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My 85 IROC was originally equipped with a 155 LG4. Check this link for more info:
https://www.thirdgen.org/1986-chevy-camaro
JamesC
Old Aug 29, 2006 | 09:39 AM
Midwest Muscle's Avatar
The '86 TPI engine wasn't rated at 215 like the '85 TPI engine. Apparently in 86, they used the weaker LG4 camshaft in the TPI which knocked about 20hp out of it. Only GM could perform that brilliance :-)
Old Aug 29, 2006 | 02:06 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Just look at my sticky at the top of the page called Camaro Engine Options. Here's a link for your convenience:
https://www.thirdgen.org/forums/hist...e-options.html
Old Sep 3, 2006 | 12:45 AM
cmn8989's Avatar
yep, I got that 195hp 305 one! It wouldnt have affected my purchase either way. Thanks alot for the input though, I really appreciate it.
Steven 86IROC-Z
May 24, 2026 04:52 AM
ChaseDale3and8
Sep 1, 2015 01:49 PM
michealleger
Aug 26, 2015 03:29 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
