Purple
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
According to the "Camaro Whitebook" there were 8,588 Code 84(WA 9802) Purple Haze colored Camaros.On Camarosource.ca the same number is listed but it gives the color as Hawaiian Orchid/Purple Haze.Was Orchid the Pontiac name for the color I wonder.Anyone have a factory Purple '92 Firebird?
Off hand I would say that purple wasn't available on the Pontiac. Most of the time when you see multiple names for a color they're from GM, and the actual manufacturers of the paint.
there are 5 for sale locally here in michigan. teal and purple are the most common colors to see running around michigan. i have personally cut up 3 of them and currently own one.
not that it means a thing other then here they aren't too rare. however total that up with 8,000+ cars and all the states they aren't too common nationwide.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The colors for Firebirds are as follows (from Pontiac)
91 - 92 -- 10 - Bright White
82 - 85 -- 11 White
85 only -- 12 Silver Met
85 - 87 -- 13 Silver Met
86 - 90 -- 13 Silver Met (Accent color)
83 - 85 -- 15 Silver Sand Met
82 only -- 16 Silver Met
92 only -- 18 Dark Jade Met
82 - 85 -- 19 Black
82 only -- 21 Light Blue Met
83 only -- 22 Lt Royal Blue Met
86 - 87 -- 23 Bright Blue Met (a med blue)
88 - 91 -- 23 Silver Blue Met, (aka Maui Blue)
85 only -- 26 Dark Blue
83 - 84 -- 27 Dk Royal Blue Met
86 - 87 -- 28 Midnight Blue Met ( a really dark blue)
82 only -- 29 Dark Blue Met
85 only -- 30 Bright Blue Met
92 only -- 37 dark Aqua Met
86 - 90 -- 40 White
86 - 92 -- 41 Black
83 only -- 42 Lt Green Gray Met
82 only -- 45 Lt Jadestone Met (Blue/Green)
91 - 92 -- 45 Dark Green Met
83 only -- 48 Dk Green Gray Met
82 only -- 49 Dk Jadestone Met (Blue/Green)
85 Only -- 50 Yellow
86 - 88 -- 51 Yellow Gold
92 only -- 52 Jamaca Yellow
85 only -- 54 Yellow Beige
82 only -- 55 Gold Met
83 - 84 -- 55 Gold Met (accent color)
85 only -- 60 Lt Chestnut Met
86, 87 -- 60 Lt Champagne Gold Met.
83, 84 -- 62 Lt Brown Met (upper & Accent color)
85 only -- 62 Dark Chestnut Met
88 only -- 63 Medium Orange Metallic
86 only -- 66 Russet Met
82 only -- 67 Dark Gold Met (accent color only)
83, 84 -- 67 Dark Brown Met
86 - 87 -- 68 Dark Brown Met
85 only -- 69 Russet Met
86 - 89 -- 74 Flame Red Met
82 - 85 -- 75 Bright Red (called Blaze red in 85
90 - 92 -- 75 Brillient Red Met
82 & 85 -- 78 Maroon Met
92 only -- 80 Bright Blue Met
86 - 92 -- 81 Bright Red
83, 84 -- 82 Dk Sand Gray Met
82 only -- 84 Dark Charcoal Met
86 only -- 84 Medium Gray Met. (also used as accent color)
88 - 91 -- 87 Medium Gray Met
89 - 91 -- 98 Bright Blue Met (similar to 86 & 87 #23)
nope no purple...
John
82 - 85 -- 11 White
82 - 85 -- 19 Black
86 - 90 -- 40 White
86 - 92 -- 41 Black
nope no purple...
John
Engine: LU5 305 CFI
Thank you Okfoz for taking the time to supply the list.Well I was just wondering if Pontiac used the same color pallete as Chevrolet.I know that divisions were assigned colors in part due to sales of particular models.Basically just thinking(typing)out loud.I also noticed Pontiac didn't use Code 59 beige that's on my '83 Z28.
Hotrodboba400
Dec 10, 2019 07:07 PM
Elephantismo
Feb 13, 2019 12:51 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
