Original Decals location.
#101
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Original Decals location.
I see this 9 year old thread never made it to the Stickey's
Make this a sticky
Make this a sticky
#102
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It may have been at one time... We had way too many stickes at one point... My suggestion might be to JT to see if we can actually get a special page for things like this...
#103
Engine: 4++,350 & 305 CIs
Original type stuff should be in the History section correct?
#104
Car: 1992 Firebird
Engine: LH0 3.1L V6
Transmission: Automatic 4 Speed w/Overdrive
This is an old thread but I'll ask since it is the best I've seen so far on decals. I have a 1992 base model Firebird. It needs repainting but I'm confused about the bird decals. My car is white (U9567) but I can't tell if the bird decals are dark gray, or silver or what. Anyone happen to know the correct color and the GM part number? Is it the same for the hood and sail panels or is there one for the hood and another for the sail panels? I've not been able to find a code on the RPO tag to tell me. If it would help I can post it here.
#105
AFAIK, only White, Silver & Yellow used CHARCOAL
Blue, Red, Black, Gray, Charcoal, Green used SILVER
There was a Gold Emblem option for one year for the Base Firebird, I believe 1992, as well...
Being a Base Firebird, there should not be an HOOD decals, it is on the nose.
The Sail Panel and the hood emblems use a different part number, but IIRC they are actually the same design, the difference was the backing (for layout) was different... might be wrong, but that is what I recall...
I just got 3 of the cheapest one when I did my car the first time,
You probably have to go thru Phoenix Graphics now, the Dealer probably does not offer them any more.
John
John
#106
Car: 1992 Firebird
Engine: LH0 3.1L V6
Yes, you are so correct, it is on the nose, not the hood. Thanks so much for the information. I've not been able to find that information anywhere. I did suspect that the nose decal was one part number and the sails were another but I agree with you that they are the same design. So my white 1992 Firebird needs Charcoal decals. Now I know what to look for.
#108
There are 2 different styles of these decals. The one pictured is for the base radio cars.
They pop up on Ebay now and then plus I think someone has reproduced the ones for upgraded radio cars
#109
i would not have thought they would have used 2 different decals based on the radio... Did the "Theft Lock" radios have a different sticker?
#110
Yup, atleast thats what I have seen. I thought it was just a running change that was made but they used both at the same time early on. (1989 TTAs used these)
#112
I like the stickers I have on my windows
"Do not open above 145 mph"
John
John
#113
Engine: 5.0 EFI
What year did GM (Pontiac) start using these window stickers.??
#115
Engine: 5.0 EFI
That explains the difference in my 86.I bought a replacement window for my 86(scratch)and mine doesn't have the white plastic pieces that's on the replacement.my question is now,are the holes the same?do I just remove the glass from the frame and swap it over?
OPPS!!!Posted the wrong pic.
#116
I pulled a 3 line decal off a early 4thgen in the boneyard.
#118
I think my 89 has it.
#119
Engine: 5.0 EFI
I found out the replacement window is from a 92 Firebird,it has the 2 line CLEAR sticker.
#120
Car: 1992 Firebird
Engine: LH0 3.1L V6
Someone asked about the door decal at the beginning of this thread and I don't think I ever saw this site listed. I found it on another tread but don't remember which one. This site can help with the sticker on the door, you need a good clear picture of it for them to reproduce since it is car specific.
http://www.ecsvin.com/order.php
#122
I have been there before, and for those prices , I will fake my own stickers. .
SPID - $79.95
Tire - $79.95
Anti-Theft Labels -$29.95 each X 9 = $269.55
Total: $429.45
To put it into perspective I paid $450.00 for my 1991 Firebirds (running & driving parts car in 2008?), I paid $600 for an 1983 Camaro SC (in 2001), and a 1983 Trans Am (running & Driving rust-bucket in 1999 for $250.00). In 1989, I purchased a 1977 Buick Electra LTD for $250.00 and my 67 Riviera from AZ cost $600 in 1988... Heck I only paid $1,100 for my 1987 Formula (that I now have $30,000 into)
SPID - $79.95
Tire - $79.95
Total: $429.45
#123
Car: 1989 GTA
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
SPID - $79.95
Tire - $79.95
Total: $429.45
SPID - $79.95
Tire - $79.95
Total: $429.45
#124
The heck of it is, Today I could probably turn around and sell the 1991 for $1000 now, It runs and drives (at least it did when I parked it) the 1983 rustbucket Trans Am I could probably get $250 for the metal, same for the 1983 Camaro...
#125
Car: 91 Firebird Convertible
Engine: 305 TBI
Can you tell me what a sticker on the right/passenger door that has a GM symbol a a large bold R and DOT might mean There is a part number in very small print at the bottom of this while rectangular sticker but is hard to read. My other to Firebirds don't have one like this. It's on a 88 Firebird.
#126
#128
Engine: 5.0 EFI
Don't know if this counts as a label or sticker but there is another member,Bob88GTA with these markings on the struts towers,his is a 85 and mine is a 86 with the identical colors.The Pasanger side is white(fading away)and the Drivers side is Brown.I don't know what there for or if all Firebirds had them
#129
#133
This is a firebird/formula front bumper decal, the paper locates its position properly.
The V helps center it and the top of the paper lines up with the top center of the bumper.
I don't have measurements from the paper backing.
#134
Fuel filter decal from a 92 350 bird
#135
Car: 91 formula
Engine: 5.0 tpi
Transmission: t-5
Axle/Gears: 3.45
here is one I found under the dash of my 91 formula. Any one seen one like this?
#136
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Yes. It is a tag that shows your Instrument panel gauges passed their functional test prior to installation in your car.
#140
I just posted this info for another member but all be )(*^%$^%&^ if I can't find it.
Edit: Found it
https://www.thirdgen.org/forums/body...placement.html
Edit: Found it
#142
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
Anyone know what should be on this label? From my 91 Z28 1LE... all other markings / labels are perfect except for this one... My 92 doesn't have it...
#143
The paint mark on the centerlink? The pitman arm has one across the bottom middle as well.
#145
Car: 1992 Polo Green RS Z03
Engine: L03 - 5.0 Liter V8 TBI
Transmission: MD8 – 4 SPD Auto
Axle/Gears: GU2 - 2:73 Ratio
My front struts had little rectangular paper stickers . . sadly can't really make them out . .
Crawling around the underside of the car, looks like the rear shocks have the same stickers on them.
#146
Those strut/shock decals have a 2 letter code on them depending on options. Have a few pix at home of low mile units.
#147
How about the "Customer Satisfaction System Certification"? . . . Or the green dot?
Any advice on what to use to "re-apply" the loose corner of my door jamb decal above?
#148
#149
Trying to determine the correct color for the paper tag attached to the rear coil springs for 1987 this would be spring NNL. I think it was originally White or Beige??
Any assistance would be appreciated.
