build sheet?
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
build sheet?
anyone know where it would be on a 1992 z28? how hard would it be to get to it.. i tryed under the pass. seat and all i felt was foam padding stuff with a mesh over it
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
sometimes theres one under the carpet in the rear, but not all the time, sometimes above the gas tank, and I think on some 91-92's they put them behind the front bumper I know a few people on here found them behind there it will be in fornt of the airbox, I got lucky on my 89, and found the one under the passenger seat
Axle/Gears: G92
It's possible that it's non existant. The line didn't have to put the build sheet in the car. Many were just thrown away. Do a search and you'll see that this subject has been brought up many times on where the build sheet might be.
Axle/Gears: G92
thanks for the info i was just trying to see if there was any place else that i didnt read about.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Is there correct Service Production sticker still on the underside of the console door(VIN matches the car's VIN)?Or do you just want to see if the build sheet is still in your Z?Since she's a '92 you also have the option of going to a GM dealer parts department with your VIN(use your regristration because some like to see it is your car)and they can pull up the complete RPO list for your car.I think the system records go back to '90 although I'm not positive.
Axle/Gears: G92
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: build sheet?
I heard that the ones on the gas tank were on california cars.
Car: 89 Iroc Convertible
Re: build sheet?
I found the build sheet in my 88 camaro under the drivers seat.Ive also seen them in the carpet above the gas tank and under the center console
