1LE Control Arm
Old Jan 26, 2007 | 06:52 PM
Joel's Avatar
1LE Control Arm
For those of you scrounging around junkyards and swap meets for 1LE components, it appears that the lower control arms were stamped “LE” for quick identification at the assembly plant. Here’s a picture from a 1992 1LE.
Old Jan 26, 2007 | 08:12 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
why would anyone want those? When boxed or tubulars are dirt cheap
Old Jan 27, 2007 | 07:19 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Possibly if you were doing a restoration on a 1LE car they would be needed.If judges take off points for not having the correct oil filter or battery then you'd probably lose points for having incorrect LCA's.
Old Jan 27, 2007 | 10:18 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I guess.... I do not think I could ever be satisfied with a stock thirdgen ever.
Old Jan 27, 2007 | 01:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 1LE version has a higher durometer rubber bushing. The whole business is still available from GM, I think. I have the part # around, should anyone be interested.
JamesC
Old Jan 27, 2007 | 02:17 PM
coolram62's Avatar
Engine: LU5 305 CFI
JamesC do you know,besides the stiffer bushings,if the control arm itself is different from the standard issue?
Old Jan 27, 2007 | 04:06 PM
JamesC's Avatar
Originally Posted by coolram62
JamesC do you know if the control arm itself is different from the standard issue?
Sorry, I don't. Here's what my 5.7L HO (ZZ3) Camaro Conversion manual states:
"The rear control arms...have high-durometer (50K) bushings. These harder bushings reduce wheel hop under hard acceleration. (For comparison, production bushings are 11K.)
"These heavy-duty rear control arms are direct replacements for the original control arms."
The part number, 10164151, is good at GMpartsDirect.
JamesC
Old Jan 28, 2007 | 03:30 PM
coolram62's Avatar
Engine: LU5 305 CFI
Thank you JamesC for the info.The stiffer bushings maybe the only difference.
Old Jan 28, 2007 | 04:26 PM
JamesC's Avatar
My guess.
JamesC
Old Jan 29, 2007 | 06:20 PM
RPM WOT L 98's Avatar
As far as I know for the LCAs and PHB the only difference was the bushings, nothing else. Both of the above are still available from GM.
Old Feb 2, 2007 | 05:19 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
nm
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
