82 recaro
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
82 recaro
my cousin has an 82 recaro trans am, 4spd, 305 carb, hes going to crush it because he doesnt want it anymore, so he asked me if i want anything off it for my 86, what is worth taking off it? im already taking the disc brake rear/lines/booster.
is the rear just a 10 bolt 7.5?
is the 4spd trans anything special?
would the sways be an upgrade over what i have?
what else should i grab?
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
how about the whole car
four wheel discs are rare i believe that one might be a WS6 car bec four wheel discs are standard with the WS6
Engine: 2002 Ls1
Transmission: t-56
i dont really have room for it, does anyone know the specs on these? rear end gear ratio, if the 4spd is stronger than the 5sd, if the rear is differant than the later models, what diamiter the sway bars are.
also i have a q, what is the 9 bolt and what cars were they found on?
Engine: 2002 Ls1
Transmission: t-56
i may do that, the engine is junk in it, but i do have a pontiac 428 i could drop in it, since its mechanical linkage i could just drop an m22...or ill put my 305 from my 86 in it and put my 350 in my 86.
I still need the specs on it though!!
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
What condition is the car in overall? Basically it is only a Regular 1982 Trans Am with Recaro seats, and if the wheels are stock, they are gold vs. silver on a regular trans am. Also the door handle inserts should say "Recaro T/A" Other than that, there is no difference. The Crossfire Injection was the more popular engine and you could only get it with an automatic. The 4speed is a mechanical linkage type and was replaced in '83 with a 5speed. I wouldn't trust the 4speed to a strong engine, I mean stock these TA's only had 160 hp with CFI so the carb is probably a little lower.
As far as specs go, just look up the specs of an '82 TA.
Engine: 2002 Ls1
Transmission: t-56
thats not true, there were more differances than the seats.
http://www.ohok.com/82recaro/appearance.html
=1982TA;3263684]What condition is the car in overall? Basically it is only a Regular 1982 Trans Am with Recaro seats, and if the wheels are stock, they are gold vs. silver on a regular trans am. Also the door handle inserts should say "Recaro T/A" Other than that, there is no difference. The Crossfire Injection was the more popular engine and you could only get it with an automatic. The 4speed is a mechanical linkage type and was replaced in '83 with a 5speed. I wouldn't trust the 4speed to a strong engine, I mean stock these TA's only had 160 hp with CFI so the carb is probably a little lower.
As far as specs go, just look up the specs of an '82 TA.[/quote]
Car: 1982 Trans Am
Engine: SBC 400
Recaro's were only Black w/gold trim.
Had Recaro Seats
Had "Recaro T/A" door handle inserts.
Had Gold Turbocast wheels with gold pontiac logo hubcaps
Had rear disc brakes WS6
so basically it is just your regular Trans Am with Recaro seats, door handle inserts and different colored wheels w/gold logo hubcaps.
There is no other performance options to make it better than a regular TA. It was basically an appearance package. And while Recaros got priority for disc brakes, it doesn't mean a regular TA with the WS6 package couldn't get them either, however there were shortages for regular TA's w/ the WS6 package later on.
One other thing to note, there were 2 variations of the door panel bird insert. There was a red bird with silver outline, almost looking like a second gen bird logo, and there was another one with the new thirdgen logo and it was gold. I do not know if these were on Recaro's or not since nobody can ever give me a straight answer. However the red bird logo (2nd gen looking) DID NOT COME IN GOLD. I don't care what anyone says, if you see them on Ebay as I have countless times, THEY ARE NOT GOLD, they never came in gold. They look gold because they are old, faded, and oxidized. I bought 2 sets off of ebay thinking they were gold, and they looked gold...untill I cleaned them up with plastic polish and then they were in fact SILVER!
Just a side note.
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Just a Trans Am with nice seats?
" Many perks that would otherwise be invidivually optional are bundled into the Recaro Edition package. For example, 4-wheel disc brakes, positraction, t-tops, WS6, and quicker steering ratio are all included in the Recaro package"
Look for the gold PMD arrow on the hubcaps, I doubt that they are still there, but non Recaro cars had the red arrows.
Sounds like it has a LG4 mill, there should be no cowl induction, plate is blocked off (1982 trait)
Dont crush it!
The BW 9 bolt was first installed in 3rd gens by Pontiac in 1985 and has several advantages to other rear types.
Dont crush it!
Engine: 2002 Ls1
Transmission: t-56
im still not a 100% sure its a recaro, i havent seen it and i didnt tell him about the whole recaro thing yet, however he said it has disk brakes in the rear for sure and he says he thinks it has the gold wheels, so i asked him about the door handles and he will check tonight
basically, if its a recaro ill take the car, if not ill take the rear and some other parts....btw how strong is the saginaw? and what size are the sways?
Engine: 2002 Ls1
Transmission: t-56
Re: 82 recaro
ok, i found out today the car is in fact a recaro, i havent seen it yet, but he says the seats are covered and the wheels are in good shape, it also has the recaro door handles. how much are these parts worth?
Engine: 2002 Ls1
Transmission: t-56
Re: 82 recaro
any idea how much the seats, wheels, door handles, and door panels are worth?
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: 82 recaro
Being a Recaro and an 82 it MIGHT have the aluminum hood, it was an option in 1982 and the original purchaser may have opted for it...
The hood in itself is worth $1000 if its in good shape, if its perfect I might suspect somoene would give you more for it.
John
John
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Re: 82 recaro
The trans isn't really a performance piece and neither is the rear-end and the rear disc brakes on those cars were particularly problematic (corrosion, seizing, falling out of adjustment). However, as a whole on a relatively rare, complete, and original car they are a small peice of history worth keeping and restoring. I would put it on e-Bay long before crushing it!
Engine: 2002 Ls1
Transmission: t-56
Re: 82 recaro
i know the hood isnt perfect, but ill put a magnet on it and see if it sticks.
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
Engine: 2002 Ls1
Transmission: t-56
Re: 82 recaro
the cars junked up guys, i dont have the time or money to fix it up, i will sell stuff off it, and keep what i like, i may have the seats redone, and keep the ground effects and fenders, maybe the recaro door handles, as well as the disk brakes and trans.
Last edited by firechicken76; Mar 28, 2007 at 12:42 AM. Reason: Automerged Doublepost
Car: 1989 Camaro RS
Engine: ZZ4 350
Re: 82 recaro
Agreed, she's rough as a corn cob. Is that hood latch area completely rusted-away?! The seats look fairly ratted-out too. If you do part it out I'd be interested in the seat tracks!
Engine: 2002 Ls1
Transmission: t-56
Re: 82 recaro
anyone know how much it would cost to have the seats redone??
Car: 1982 Trans Am
Engine: SBC 400
Re: 82 recaro
Hey, I was wondering if the bump strip on the drivers side fender is in good shape?? It's the one in the second to the last photo. It looks like rust behind in on the fender but I can't really tell. I'm pretty sure the metal part was aluminum and wont rust, but I believe they were just stuck on there with adheasive. Anyway, I need it! Would you be willing to CAREFULLY pry it off and sell it to me?? They don't make those and repros are non existant.
Actually I guess they would both be the same on either side, so if one is better than the other, I'd like the one in the best shape.
let me know.
let me know.
Car: 1982 Trans Am
Engine: SBC 400
Re: 82 recaro
I've heard of Recaro's getting the "thirdgen" bird emblem on the door panels. I'm not sure if regular TA's got them also, but if they came w/his car they are probably correct. They are probably a little more "rare" than the red/silver bird like you and I have in my TA.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Re: 82 recaro
ewwwww... that car has seen better days! Still plenty of good parts though, definately take it home and start a "parting out" thread in the classifieds!
Car: 1983 Daytona Trans Am
Engine: LG4
Re: 82 recaro
The 1982 Recaro only had gold N89 wheels with black caps and a gold arrowhead.
Car: 1982 Trans Am
Engine: SBC 400
Re: 82 recaro
I'm not sure what your point is, I never said those parts were specific to the recaro. I told him he could make a little money off of the parts I listed. One question for you; since the car he found is an actual recaro we are assuming all of it is original, correct? Since those silver door panel bird emblems are on his car they must have came with it 25 years ago. Now, since that is the case, how many different style wheels came with the 82 recaro? The wheels he has pictured must be original then too. I'm not sure how the original black bowling ball hubcaps are going to snap onto the wheels he has pictured...
Car: 1982 Trans Am
Engine: SBC 400
Re: 82 recaro
Things that I do know;
~~The interior door panel bird along with the wheel I posted above are original and did come with my 82 recaro 25 years ago.
~~82 recaro ta's are much more "rare" than plain jane regular 82 black and gold ta's.
~~82 recaro ta's are worth more money than 82 plain jane regular ta's.
~~No matter what kind of interior door panel bird emblems, door handle inserts, or whatever else a person sticks on a regular 82 black and gold ta it still will be a regular 82 ta, and not an 82 recaro ta.
I still think firechicken76 should part that thing out.
Re: 82 recaro
i'd like to know this too. i might be picking up a recaro in pretty much the same condition as that one.
what about the disc brake setup? is that of any interest? how much is someone willing to pay for it?
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
Re: 82 recaro
Last time I priced this out it was going to cost almost as much as it would to buy a new recaro off the net.... I would just try to sell them outright unless you can find a decent upholstery shop to redo them for a reasonable price. From the look of them they'll need to be stripped completely and have new foam and material.
Engine: 2002 Ls1
Transmission: t-56
Re: 82 recaro
