How rare is it to have an option for a I believe its called a center console clock in a 84 Z28 ?
The console clock(RPO-U35)is an uncommon option that was available in '82(14,166),'83(1,992),84(1,840)and '85(809).The production numbers are from the "Camaro Whitebook" and is for all models.It states the clock was standard in Z28('82-'84)and Berlinetta('82-'83)but was deleted if a digital radio was ordered.But since it was on the option list you could still order it or it wasn't deleted("Whitebook" is off on some of it's info).My '83 has it and I've seen a couple more in person that had it(I've seen a few in pictures).I'm guessing with the more common use of the digital radios with clock and the low number of console clocks ordered Chevy discontinued it.But the console top cover mold wasn't changed.If you look at the bottom of a top cover(at leat thru '90)you'll find the 3 mounting post for the clock.The clocks have a bad reputation even though they are quartz movements.I'm guessing where they are mounted didn't help.I can attest to that possibility as I cracked my Z's original one when I leaned on it doing another repair.
Well aleast there's something different about my car. To bad the clock works when it wants to. I will have to try and pickup another sometime.
pretty common, i had an 83 z28 with one
theyre around
nothing rare by any means at all
i see aluminum drums less than i do the console clocks
the clocks are crazy fugly and arent even digital or anything else cool at all
good luck
theyre around
good luck
Well by COOLRAM62's numbers 1,840 cars only had them seems on the rare side to me when there was 261,591 cars that year
JamesC
close
Quote:
I have one of the 809 in my 85 IROC (AM radios didn't have a digital clock apparently). Before I replaced mine, I removed it, shot it clean with canned air, then drenched the clock works in WD-40. It's been keeping time quite nicely for several years.Originally Posted by 84 z28
To bad the clock works when it wants to. I will have to try and pickup another sometime. JamesC
Drew
close
- Join DateJul 1999
- LocationSalina, KS
- iTrader Positive Feedback100
- iTrader Feedback Score(58)
- Liked:1,068 Times in 759 Posts
Somewhere along the line I read that someone thought it'd be more like the cockpit of a jet fighter with a clock stabbed in the middle of the console. I've seen a couple of them in person.
mine in my 85 z28 works just fine and i installed a led blue light for it and it looks great at night and alot of people ask me about it
I think the console clock is one of the cooler options available for camaro.I installed one in my 86 iroc and 89 iroc vert.It gets quite a bit of attention at car shows as most people have never seen or heard of them.I also have about 10 more clocks packed away in a box
sofakingdom
close
- Join DateSep 2005
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,485 Times in 1,897 Posts
Not rare enough IMO... makes an otherwise "state of the art" car, for its time, unexpectedly include a relic from the Stone Age. About like "restoring" a Model T and putting in an in-dash hard-drive music player with GPS. Mismatch.
navy02ws6
close
I thought they were cool until I found out that only cars with base model pushbutton radios without digital displays came with them. Same deal with 1981-82 Corvettes, and B-Body cars of that era. The 1981-82 Corvettes got an oil temp gauge in place of the clock if they had the digital stereo.
